Is there a easy way to change images without transition loss
tstn
Is there a easy way to change Images in a project that is already started without the loss of the transitions. I have lots of images to change and the transition colors are already set. I do not want to loose the transitions. I have several hundred Images to change. Thanks for the help. TS
Hi TS
welcome to the forum again
The easiest answer if i understand your question is 'No'
Did you read your previous post
http://phpbb.ulead.com.tw/EN/viewtopic. ... ght=#88116
With Regards
Trevor
With Regards
Trevor
