Is UVS 10 Service Pack valid for processors AMD x2 DualCore
fofilou
Post by fofilou »
I have a processor AMD Athlon x2, and I would know if the Ulead VideoStudio 10 Pack 1 service was also valid for this type of processor? Thank you in advance.
My PC is Acer Aspire E360-YB7V
frantid
Re: Is UVS 10 Service Pack valid for processors AMD x2 DualC
Post by frantid »
fofilou wrote:I have a processor AMD Athlon x2, and I would know if the Ulead VideoStudio 10 Pack 1 service was also valid for this type of processor? Thank you in advance.
I believe the answer is a qualified "yes". I have a x2 4400. VS10 does not take both cores up to 100% It also does not take just one core to 100%. There seems to be multiple threads depending upon your choice of output file or encoder -- mpg, avi, etc. It does spread the load between the 2 cores but it is not a 50/50 split in cpu utilization -- the different codecs seem differently balanced. The mpeg encoder is fairly balanced. One core will work harder at times then the other and it is not always the same core. It seems faster with sp1, to me.
I actually like that it does not take both cores up to 100%. I'm always doing something else with video files on a different drive during the encoding process, so it's better not to have both cores tied up for me.
fofilou
Post by fofilou »
Thank you
CycleWriter
Post by CycleWriter »
frantid wrote: I believe the answer is a qualified "yes".
I'm not so sure. I've burned a few projects on my AMD X2 4200+ and I've yet to see any CPU utilization above 70%, with the general average being 45-51% during rendering. I don't multitask when burning a video so I'd prefer to see more CPU usage and shorter rendering times.
frantid
Post by frantid »
I agree, I never see a max -- but I do see both cores working, never just one at 60% and one at idle. This cpu has really shown me how speed limiting sata 150 is. I need to get to sata 300 to see what the cpu can do.
CycleWriter
frantid wrote:I agree, I never see a max -- but I do see both cores working, never just one at 60% and one at idle. This cpu has really shown me how speed limiting sata 150 is. I need to get to sata 300 to see what the cpu can do.
Can I ask, how are you monitoring BOTH CPU cores during a render process? I can monitor CPU cycles while using my computer, but I can't distinguish between cores. Is there a program that allows you to do this? :?:
frantid
Post by frantid »
You can use windows task manager. On the performance page you should see 2 history graphs - one per cpu. If you don't see them, go to view -> cpu history -> one graph per cpu. Personally I use rmclock to set my cpu speeds for AMD's cool and quiet and monitoring utilization . My video editing machine also runs Snapstream BeyondTV so I run it all the time, rmclock allows it to run cooler and speedfan slows the fans down as needed.
http://cpu.rightmark.org/products/rmclock.shtml
rmclock takes some tweaking though, I went through a lot of BSOD's to get it stable.
CycleWriter
frantid wrote:You can use windows task manager. On the performance page you should see 2 history graphs - one per cpu. If you don't see them, go to view -> cpu history -> one graph per cpu. Personally I use rmclock to set my cpu speeds for AMD's cool and quiet and monitoring utilization . My video editing machine also runs Snapstream BeyondTV so I run it all the time, rmclock allows it to run cooler and speedfan slows the fans down as needed.
Thanks! I did not know that about Task Manager. :lol:
:!: :!: :!: :idea: :lol:
No more needs saying!
