Project Settings
rent
Project Settings
I've made my slideshow and selected the option to auto repeat after disc playback ends, however, once the disc is burned and played.. it goes to the default dvd player screen and shows the square "stop" icon. Same thing happens on two other standalone dvd players. I'm trying to create a looping video display for my store and was under the impression that this software would allow me to create such a dvd. Any suggestions?
Burn to a folder first and check it with a DVD player program to make sure the project settings are correct. It should work and repeat at this stage.
If it repeats properly when played on the PC from the folder but not when burnt, then I would either burn slowly or use other software to burn.
If the burning speed was not the problem then I have one more idea.
Maybe your DVD is less than 1GB full, in which case the burning process should create an extra long lead-out for compatibility.
I don't know if MF does this. Nero does, unless you disable it.
Henry
