Problem with 16:9 video
hanskru
motherboard: Ultra Durable Gigabyte Technology
processor: Intel Core i5
ram: 4GB
Video Card: NVIDIA GeForce 8400 GS
sound_card: High Definition Audio
Hard_Drive_Capacity: 500Gb
Monitor/Display Make & Model: ASUS All i8n one
Corel programs: Ultimate 2020 upgrade
Post by hanskru »
I am a VS user since VS5. Now I want to capture 16:9 video from my Sharp DV.
Project properties set to 16:9, than captured video. Captured video (thumb nails) shows on top and bottom black bar.
In the preview screen also a black bar on top and bottom. When I load a captured scene into the preview screen, than I got a double black bar on top and bottom.
Please advise,
brgds hans
Hans
VS 5.0,6.0,7.0,8.0,9.0,10,12, X3, X4, X5, X6 Ultimate,X7 Ultimat, X8 Ult, X8.5 Ultimate,VS1018Ultimate, VS2019Ultilate,VS2020Ultimate
JVC Everio GZ GX1BE
Post by Trevor Andrew »
Hi Hans
Have a look at my guide ¡¥16:9 a look at widescreen¡¦ from the link below.
It shows how the video should look when using a widescreen frame.
Does your Sharp DV produce proper 16:9 or does it merely add black bars over the 4:3 frame to simulate the 16:9.
If the latter then the library thumbnail will show these bars.
To be sure you need to capture to DV via firewire, Right click a captured file ¡Vselect properties¡Xdo they indicate 16:9 or 4:3
Hope this Helps
Trevor
hanskru
ram: 4GB
Post by hanskru »
Hi Trevor,
Captured video shows properties 16:9 and the thumbnails do show black bar on top and bottom.
This means in mij preview screen I got a double black bar on top and bottom. When DVD burned I a black bar shows also on TV on top and bottom.
So any suggestion?
Thanks anyway for your support,
brgds Hans
Hans
JVC Everio GZ GX1BE
hanskru
ram: 4GB
Double black bars top and bottom
Post by hanskru »
Hi VS Friends,
I am still struggling with the double black bars.
Captured video properties: Compression: DV Video Encoder Type 1
Attributes 24 bits, 720x576, 16:9
Total frames 1547
Project properties : PAL 25fps
Microsoft AVI files
24 bits, 720x576, 16:9, 25fps
Lower Field First
DV Video Encoder Type 1.
I also did as mentioned in Trevors video guide.
So I preview screen I have double bars and when burned DVD one black bar on top and bottom remains visible at TV wide screen. Normalle this black bar disppers.
Any more suggestions?
brgds Hans
Hans
JVC Everio GZ GX1BE
Hi Hans
Sorry to hear you are still having problems.
I have been on holiday and away from the forum,.
Did you solve the problem regarding the 16:9 black bars.
I did a search for your camera specification and it would appear that it does not support true 16:9 widescreen ('anamorphic video').
Your camera only places a bar over the 4:3 screen simulating widescreen.
You should capture to 4:3 ratio.
If you are capturing to DV format (via Firewire) you will not be able to select the aspect ratio,
The information on your camera is transferred to VS.
What you have on the camera is what you get on the pc, no re-coding takes place. You will capture 4:3
The files will be DV-Avi at 13 Gb per hour
Trevor
