1) Is there a way to increase/decrease the size of various objects in the timeline by using the arrow keys to move 1frame at a time, rather than having to fool around with the mouse dragging so that I can get my cuts more accurate?
Yes there is...
- First go to your Preferences, File menu>Preferences or just press F6. Then on the first tab, look for Clip Display Mode. Click on the drop-down arrow and change it to Thumbnail Only.
- Go back to your timeline, and you should see just thumbnails of your video clips. Each thumbnail can represent 1 Frame. To see this...
- Look just beneath your Preview Window, player control buttons. There are 2 magnifying glasses, and a slider. That magnifies the timeline. Slide it back and forth and watch the numbers on the timeline change. Now you can also go to the extreme left side of that number line and right-click for a menu. Select zoom to 1 frame. Now each tick on the number line represents 1 frame.
2) Is there a way to hear the audio while adjusting where a video clip or picture starts and ends so i can get them to appear in unison with say a drum beat or loud bass in a song?
Unfortunately in VideoStudio there is not. That's a feature for big brother MediaStudio Pro. However like many things, there is a workaround. This came about in VS10 +, and was not there in VS9. You can use the
Chapter Markers to place marks where the beat of the bass drum falls with your video. Then go back using the chapter marks to adjust your clips.
Somethings that you need to learn, are some Keyboard shortcuts. When getting into things like this, it makes things a lot easier. For instance, press the
Tab key and look at the blue arrow on the timeline. It starts flashing. Now you can use the arrow keys on your keyboard to advance, or go-back. Single tap of an arrow key=1 frame. Hold the arrow key down and it plays, forward or backwords. Now press the
spacebar, the clip starts playing. Now to mark your timeline, press the space bar, listen to your music, then stop it, and using your mouse place a chapter mark. Continue in this manner until you have all the marks placed. Now you have a visual reference to adjust your video to.
As for cutting clips in the overlay, I don't understand exactly what you mean, but I am sure I will find out as time goes on. Whenever you may get a free moment to explain that would be great!
Cutting clips is no different then it sounds. Just think of your video clips as the old film. To edit out a segment, say of when you forgot to shut off the camera, and you have this nice piece of video of your feet. Well with film you would use a film cutter or scissors to cut the film. Your clips are handled the same. There is a pair of scissors on the lower right of the preview screen. Pressing it while a clip (in clip mode) is highlighted will cause the clip to be cut into two segements.
Finally, what exactly is the point of the overlay? If I can just add my images and videos to the video track..why use the overlay?
The overlay is simply another track to add video, images, or color clips (which are bitmap images). The overlay tracks allow you to create some neat things. Overlay tracks are commonly used by TV news. The next time you watch the news. look at the titles at the bottom of the screen, the logo, the time, the colorful background, split-sreen (picture in picture), those all use overlay tracks. While for home video it is not necessary to use, it is the means to turn a boring video into something everyone can enjoy..
Hope that has helped..
