Black Lab wrote:I did not say that Auto Fade Out... was causing your problem. I said that it was the problem in my case. What I said was you may have to experiment with some of the menu options because, as it seems, something there is causing problems. That could be why, when Create Menu is unchecked, it works fine.mecute wrote:Hi, "Auto Fade Out First Play To Menu" is already unchecked on my settings. I have no idea why its always crashing everytime i click next with the "create menu" selected... if i uncheck "create menu" option it gives me option to preview and burn a dvd. Please help if there is another way. My movies are too long to burn without a menu option.
Regards.
You also didn't answer John's question regarding your burn properties. Please answer the questions you are asked if you want us to try and help you.
Yes, i have followed the instructions for setting up my burn properties manually. Its seems to not work still. Thank you for your help.
