I imported 2 separate video files, which totals about 6hr, 10 min.
So I edited out (using Mult-trim) enough commercials to get the length down to 5hr, 57 min. Now it should fit on a 4.7GB DVD>
But MovieFactory 3.5 thinks it needs 9.34 GB. Huh?
Thanks,
Kurt
Does trimming a video add to the size of the file?
kurt
Additional info
I also noticed that a similar thing happens when I import the VIDEO_TS from a 6 hr DVD that I recorded on my standalone DVD recorder.
After the import, the length in time is shown as 6 hour 2 min.
But the space required to burn to a new dvd is 8.42 (7.84) GB. Ulead MF 3.5 clearly changes something from the original format, but what? How can I get the size down?
Thanks in advance for any help!
Kurt
Kurt
kurt
Even more information
I "think" I figured this out. I created a new custom MPEG setting that I called "SLP-6hr" with the Video Data Rate set to constant 2000. (Maybe I should have used variable 2000? I'm not sure.)
Now when I import a 6 hr DVD, the project size is 4.73 GB. Not sure where the extra 30 MB came from, since I set the menu motion to 1 sec, and told it to NOT write the project info to the disc.
But at least now it's workable.
Did I do this right?
Kurt
Kurt
To get it to work? Yes, however with using a bitrate of 2000, the quality is going to be, well... horrible... The lowest quality that I would accept is one of VHS, which is generally around 4500 at the bottom end.
Do yourself a favor and don't try to cram 10 pounds of stuff in a 5 pound bag. Use more disks. You should split the 6 hrs up over 3 discs, and have a watchable, qualitiy DVD.
Then you could also try using DVD Shrink, http://www.dvdshrink.org/what.html and shrink it down to a size that might (I doubt it though) fit onto a single layer disc.
Six hours of video is better burned onto dual layer discs.
kurt
Thanks for the advice
Thanks, Ron.
The dvd's were originally created in 6hr mode because they're baseball games that were played during the day while I was at work, and the 6hr mode was the only way to capture two games on a single rewritable dvd. Now I'm trying to mix and match them together the way I want.
Will I really get better quality using a higher bitrate (given the way they were originally created)? If so, it sounds like I should/will split the capture, and put 1 game on a dvd.
Kurt
Kurt
