Install problem ver. 8.0SE Basic
Noops
Post by Noops »
Win98SE
Photo Explorer 8.0SE Basic
Program installs.
When run, program loads, then an error message comes up from the Pex program:
PEX executed an invalid instruction in
module XVID.DLL at 0167:02f55fe7.
Registers:
EAX=000000f0 CS=0167 EIP=02f55fe7 EFLGS=00010206
EBX=00a93250 SS=016f ESP=00c9e26c EBP=030688e4
ECX=80000000 DS=016f ESI=00a92da0 FS=3d7f
EDX=00000000 ES=016f EDI=00a92da0 GS=0e9e
Bytes at CS:EIP:
0f 4d d1 8b 4e 10 85 c9 0f 84 da 00 00 00 83 f9
Stack dump:
82ba4e58 00c9eb14 bffa1d67 00c9e2ac 81626d4c 82ba4e54 c159e990 00c9e2ac bff7a10e bff7b326 82aa3000 00000000 00000003 82ba4df4 bff76f10 00000003
At this point I close the error box and Photo Explorer closes down.
Please advise what to do.
Thank you.
htchien
operating_system: Mac
Post by htchien »
Some versions of XviD CODEC pack are not compatible with Ulead products. You can try the following solutions to see if they fix.
Update your XviD CODEC pack version.
Or,
Rename uvAVI.vio and uvQT.vio in the VIO folder under the install path of PhotoExplorer. But this will make your PhotoExplorer cannot play Windows Media files and QuickTime movie files in its file viewer. After renaming the .vio files, PhotoExplorer will invoke QuickTime Player and Windows Media Player to play those files.
Or,
Remove XviD CODEC pack in your system and use DivX CODEC pack instead. DivX CODEC pack can let your player still can read XviD video files but will have some quality loss.
You can download a free DivX CODEC pack version from http://www.divx.com
Hope this helps.
H.T.
Ted (H.T.)
