PhotoImpact 12: Initializing ResizableWnd.dll
Corwin
Hello everyone,
I recently bought an upgrade to PI 12 and installed it.
When it starts it says:
initializing ResizableWnd.dll
and after about 40 seconds it closes.
There is no message, no message in the system's log.
I tried the tips posted in this forum in this thread but
they did not work.
I also posted a message to tech-support, but did not get
an answer yet.
If I can't run PI 12 I'll try to give it back, but that's only
possible for a few days after purchase, so I have to know
quite fast, if it will work or not.
Currently I'm running PI 8, had a demo version of PI 10, which
is deleted now.
The locale is german. I've checked the libraries and they are
like 2log posted. The language of ResizableWnd.dll is Taiwan
though.
The program was installed as non-Admin user with full Admin
privileges.
Thanks for any info,
Michael
they did not work.
an answer yet.
is deleted now.
though.
privileges.
Michael
- ram: 2 GB
- sound_card: Intel GMA 950
Corwin
Please click here -->
so that we can then view your system specifications.
Perhaps you need to uninstall using Our Procedure and then using an admin user account re-install the program.
Have you tried to run the program as an Admin User?The program was installed as non-Admin user with full Admin
privileges.
Corwin
Thanks for the tips,
I first tried to repair the installation and got errors:
CRC-Error in cab-file: for
German/Info.ini
German/Setup/OEM/TargetMain/All/u32RawAdjust.dll
German/Setup/OEM/TargetMain/All/u32RAWDeNoise.dll
German/Setup/OEM/TargetMain/All/u32RotateFujiFilm.dll
then I aborted.
None of these files seemed to be in the Ulead directory.
I uninstalled it and reinstalled it.
Still did not work.
Then I called repair again, same results: CRC-Errors.
It seems either the wrong files got packaged or
the CD is really broken (copy protection?).
Or my DVD-drive is not working
correctly.
Anyway, I am going to exchange the software,
maybe another copy will work.
Thanks,
Michael
German/Info.ini
then I aborted.
Still did not work.
correctly.
Thanks,
Michael
- ram: 2 GB
Aha CRC errors - Cyclic Redundancy Check
You have a faulty disc.
http://www.computerhope.com/issues/ch000430.htm
Re: Compatibility wizard
This worked for me, too. I have no idea why. I had previously installed PhotoImpact 8 on XP Pro without a problem, but PhotoImpact 12 wants to be lied to for some reason.2log wrote:A user with Windows 2000 SP4 shared a solution that worked for him. He set the compatibility wizard to Windows 95. You can find the steps for this from the Ulead KB:
http://www.explorecommerce.com/members/ ... 31&ID=9811
Same Problem
I am experiencing the same problem on a Win 2000 / SP4 machine.
However, on my backup system with basically the same installation PI 12 starts with no problems.
I need it to work on my main system though.
The main difference between the two machines is the hardware - on my main system I have a Matrox Dualhead Graphics Adapter, that may cause the issue.
PI 11 runs very stable though.
Compatibility mode works
2log's solution does not work on Windows 2000 as stated, since the compatibility wizard exists from XP on only.
There is a way, however, to activate compatibility mode in Windows 2000, as stated on http://support.microsoft.com/default.as ... -us;279792
Why PI 12 works on one workstation with essentially the same installation, and doesn't on the other I do not know.
btw, You have to switch to "Windows 95"-mode, even Win 98 mode doesn't work. At least not on my computer.
togn54
Re: Compatibility mode works
Hallo,
I have the same problem with Win 2000 / SP4.
Windows 95 compatibility mode solves this problem, but I can
switch to w95 mode only as administrator.
How can a standard user run a program in compatibility mode?
Gianpaolo
Gianpaolo
eagleshen
try delete uipl.dll to solve the problemtogn54 wrote:Hallo,
Gianpaolo
htchien
UIPL.dll is a DLL file to load Intel optimized DLLs in Ulead products. I would not suggest to delete this file to solve the issue if you are using a Intel CPU.
H.T.
H.T.
Ted (H.T.)
togn54
Many thanks for the replies.
But again:Can a standard or power user run a program in win 95 compatibility mode?
Thanks again.
Gianpaolo
Thanks again.
Gianpaolo
togn54
I deleted UIPL.dll.
Now PI12 starts but crashes when I attempt to open a file.
Gianpaolo
I guess we know why H.T. advised against this...htchien wrote:Hi,
H.T.
I would guess that you are going to have to do a clean uninstall/reinstall now, or at least replace that driver file. Unless you know what you are doing, it's not good practice to delete DLL files..
abdliuae
