I've been using the widescreen option of my JVC camcorder, which just puts black bars at top/bottom of video.
I would rather have the end product clipped or cropped with output at 16:9 res. I'm using VideoStudio 10. How do I do it? Can I do it?
Output to be used for web... 320xWhatever.
Thanks,
Mike
Http://vlog.mikemoon.net
Can I output 16:9 from 4:3 data?
mikemoon
Thank you for the link. I followed it all the way through, but the output still seems to be 4:3.
I think this maybe in part due to the choices that I can pick from for WMV or MP4 video types.
I was wanting the output file to be in 16:9 format. 320x180
Only in MOV could I put in my own dimensions.
Do you follow?
Mike
Do you follow?
Mike
bwavin
Unfortunately some camcorders do output a pseudo 16:9. A friend could not understand why his widescreen shots looked odd in VS. I discovered that it was because the output was actually 4:3 but looked 16:9 because all the camcorder had done was put black bars at the top and bottom.trevor andrew wrote:Hi Mike
The black bars at the top and bottom are not part of the video frame.
Trevor
B
bwavin
mikemoon
Hey Trevor,trevor andrew wrote:Hi Mike
Have a look at My Quick Guide 16:9 a Look at Widescreen from the link below
One option for wmv, you should be able to render the project to Share-Share on Line
Hope this helps
Trevor
I've had some luck following your walkthrough. Although I've not been able to save in actual 16:9, the 4:3 output is much better. I mean better , in that unlike the black banners the camera, the true 16:9 is not effected by the addition of contrasting or sharpening filters.
I've checked out the custom saving option and I just don't have much of a choice. I don't have one called Neptune. Is this a different type of codec?
I'm looking for MP4 and WMV output at 320X(whatever (180)).
Update: I was able to save to 320x240 with an aspect ratio of 16:9. Then take that into Quicktime and export at 320x180 and it looks great. Now if I could just do it right through Ulead, I'd be laughin'.
Mike
