Are you aware that Panasonic has protective cartridges to hold 5 1/4" dvd media? I use them all the time because of what you posted (and laughing, I don't blame the kids when handling the media, dvd disks are fragile). If you look on the panasonic website you can get double-sided dvd-ram disks already installed into a protective cartridge. A double-sided disk you can filp them over in the record (also have write-protect tabs on the cartridges). The cartridges have tabs and the media can be removed & switched out.which I think was later converted to a more expensive/less durable frisbee by my children
If you look at the dvd tray in the panasonic units you will see the side brackets on the tray where you put the dvd's into. These side brackets line up the cartridges. They are great to have. You can throw them onto a couch or drop them on the floor and the dvd-ram disk is untouched (within reason of course).
Sometimes copying the contents to your harddisk (all the folders) first and then use the import dvd function to import the video from your harddisk. When using DVD+RW dvd's usually this format is the DVD+VR format, there were some issues with the +VR import function awhile back, it was fixed in one of the patches.
aieronimo,
Womble's software is dedicated to mpeg editing, nice software.
I can usually import the dvd-ram disks without a problem, but after your post I do remember many of the errors at the end of the import are where I cut the video.
I haven't come across the bad spot though on making a new dvd disk.
What I have come across was I put the protection feature to ON for one of the movies I had recorded and forgot it was on.
Imported that movie without any errors. It wouldn't playback correctly in my standard dvd players (only the advanced players). Removed this protect feature on the video and re-imported the movie again. This fixed this little quirk. I thought this protection was only a panasonic thing for in the recorder.
Robs idea may work, I would try a dvd-rw disk that could be re-used.
Also Rob, if you can record to a dvd-rw disk may give you better results. The dvd-ram records in the -VR format. The dvd-rw disk will create a standard dvd media dvd with the exception you can re-use the dvd. This may be more reliable. You can't trim the video or edit it though, but you can do this in VS or MF.
