The finished MPEG looks fine when played on a PC as does the DVD which was authored and burnt to disc using Movie Factory 3 SE.
The results on the TV however are disappointing. On the TV the edges of the images for the credits sequence are lost cutting off some of the text. Even if I adjust the settings on my TV between 4:3 16:9 etc. it has no impact. I was kind of expecting "what you see is what you get" as seen in preview mode).
Some help would be appreciated - I can see the finish line on a project that has taken some time to complete!
Thanks,
Nick
Movie Factory 3 SE (available patches applied)
The rendered file information is as follows:
MPEG files
24 Bits, 720 x 576, 25 fps
(DVD-PAL), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 384 kbps
The MPEG file size is 4.61GB (4.29GB) and was created using VideoStudio 8 SE.
