Hi!
When burning final dvd I always get the error stating that some chapter frame numbers are beyond the end of the disk. (or similar).
I rechecked the chapters and they were ok.
I got the same error the second time.
Then I deleted all chapters and set up new chapters. When trying to burn I got the same error.
Was I doing something wrong (my trial licence expired) or is this sw just not functional (ulead site said that its fully functional).
Thanx, Leto
Movie Factory 5 trial error
This is supposed to be fixed in MF5 Plus. If you have the standard version of MF5, there is a Service Pack that's supposed to fix it.
But, you can't try it out because you can't apply the service pack to the trial, and your trial expired anyway. So, you'll have to decide if it's worth the risk...
It's also possible that you have a corrupt video file. In that case, the service pack may not help. File corruption is common with MPEGs or other highly compressed formats (formats other than DV). This can be hard to diagnose, because a corrupt file will often play back OK, but cause trouble when you try to re-code or re-multiplex it.
DVD MovieFactory Host Update:
...Bug Fixes:
Projects set up in NTSC failed to capture from PAL devices.
Some capture cards incorrectly split captured files into 4GB segments on NTFS partitions.
Widescreen (16:9) aspect ratio was not maintained on video imported from Sony DVD camcorders.
Chapter cues were not imported from MediaStudio Pro 8 project files inserted into MovieFactory projects.
Some text and customization menu settings were lost after saving and re-loading project files.
DVD MovieFactory sometimes encountered an error and displayed the message Some Chapter Entry Frame Numbers Exceed the Total Frames?when joining multiple video clips as part of a Fast Export or rendering task.
Some menu setting were reset when loading projects after uninstalling and reinstalling the DVD MovieFactory program under different paths.
DVD MovieFactory sometimes crashed during the menu or slideshow steps when 3rd party software or codecs were running.
The DVD MovieFactory 5 Service Pack 1 is for Ulead DVD MovieFactory 5. If you have purchased Ulead DVD MovieFactory 5 Plus, you do not need to install this update.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
LetoThe2nd
