My final burn settings were as follows...
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 16:9
Audio data rate: 256 kbps
I assume if I select Dolby Digital it should get on the disk?
I captured HDV video/audio clips (no editing required).
Went directly to Create Disk and added the clips to the disk project.
Created a menu and selected the above settings.
Later I checked the project settings (I know they should all match) and found that audio was set to LCPM. Was this my problem? (I didn't have time tonight to re-render for another 3 hours)
Is this why my disk doesn't have Dolby Digital on it?
Why don't the final burn settings take precedence?
I'm spending more time dinking with settings and testing than actually doing any real work.
