THoff wrote:Yes, you can do that, provided you output to a format that supports codecs, i.e. AVI. When you go to create the file, click on the Options button, then the AVI tab, and choose an audio codec and configure it.
thank you for advice
Yes, i understand that you said, but then choosing an audio codec, you
MUST also choose the video codec (option above). If i chouse "None" it makes an output file with uncompressed video stream, if i chouse the same codec as i used capturing video (Xvid) it recompress both - audio and video streams, and i waste much of time recompressing video stream that is not very wise and, is it ?
this way compressing 1.5h clip took about 10h and at the end of the clip sound does not support the view - sound goes ~half second slower
Lithuania , Mindaugas
