Failed to Burn error
jedmgrew
Post by jedmgrew »
just installed MF5. tried to create video dvds, and slideshow dvd's, always comes up with "failed to burn error".
Checked DVD burner, that's ok.
Tried DVD+R, DVD RW, DVD-R, same result.
Tried creating a slideshow on CD, same again.
Am I missing something?
Thanks for any help......
libby
Failed to burn to disc
Post by libby »
I have VS10+ and am trying to burn three small videos (only MG worth). Everything goes fine until the output disc reaches 99% and then "failed to burn to disc"appears. I have checked the burner = OK, reinstalled the program, added the recent patch. Still comes up with same message. Any ideas of what I could try would be gratefully received.
Libby
libby
Post by libby »
DVD burner is fine as I can copy DVDs. It's just the final stage of the Ulead Share process that does not work.
Libby
Check your DVD burner manufacturers website for updated firmware.
Firmware is software built into the DVD burner to enable it to communicate with the computer.
Please also complete your system specifications Image
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 10:08 pm, edited 1 time in total.
htchien
operating_system: Mac
Post by htchien »
I would check the source files first. Are you using some MP3 audio files in the slideshow part? If so, convert them to WAV files first.
Hope this helps.
H.T.
Ted (H.T.)
libby
Post by libby »
I do have an mp3 audio file but how do I convert it to WAV? There is no save as.
Libby
Try using
Audacity.
This is a sound editor. You can export the soundtrack from your video editor as a WAV file. Open the file with Audacity and make powerful alterations, fades, cuts, mixes, clean out unwanted sounds, echos and a variety of other useful edits. You can then save the cleaned up sound file and then import it back into your video editor.
http://audacity.sourceforge.net/
Its FREE. It will also import MPG files plus a few other formats.
libby
Post by libby »
I have tried Audacity and it makes no difference but could be useful in future so thank you. Then I created an iso file and have managed to burn the three videos onto a CD. It wouldn't burn on a DVD BUT now the resolution is poor, quite pixelated in fact. Problem after problem! Any suggestions would be gratefully received. By the way how do you attach your photo to this chat session?
Libby
If you choose DVD when you started a new project I didn't think you could burn it to a CD. did you select the right one?
Regarding your photo Its termed an avater. You firstly go to your user profile page:
At the bottom of that page you will see this:
libby
Post by libby »
I am using VideoStudio 10+ not MF as you are. There is no choice with VS.
Have also tried VS9 in case that works but won't even recognise my files. Can I resave VSP files as something else then maybe I can try using MF which I also have.
Libby
LIbby,
I think Steve posted the screenshot of DMF because this is the DVD MovieFactory Form, not VideoStudio.
You can only save project files in VS as VSP (VideoStudio Project). However it is possible to Insert VSP files into DMF.
You problem with VS10+ choking could be due to a corrupt MPEG file. It's difficult to determine that without knowing if you followed the recommended procedures setout in the top sticky of the VS forum.
You might be interested in Steve's tutorial, From Camcorder to DVD. Following the tutorial you may find that there maybe a step or settings that you missed, and could help correct your problems.
