The source video is 25fps encoded by AlparySoft Lossless Codec (from DV cam)
When I watch source video in the "Edit" screen frame-by-frame all is ok, but when I try to "Create disk":
Code: Select all
MPEG files
24 bits, 720 x 576, 25 fps
Frame-based
(DVD-PAL), 4:3
Audio data rate: 256 kbps
Dolby Digital Audio, 48 KHz, 2/0(L,R)What it can be? I know that this happens when converting PAL-NTSC, but no converting here
