Problems mit DMF 5 - flickering and no capture device
Rager01
Post by Rager01 »
I have DMF 4 and now DMF 5.
The following 2 problems are only problems with DMF 5 (on version 4 everything is ok).
- I have a panasonic NV-GS 75. I can't capture with DMF 5 ("no capture device..."). On version 4 I first have to click on another driver "Medion 7134 WDM Video Capture" and then the panasonic driver, then it works. On version 5 the Medion driver is not available. So I have to capture on my version 4.
- I capture my videos as AVI then I render the project to get MPEG files. When I render AVI files on DMF 5 the result is flickering on panning (maybe from right to left or left to right -> it looks a little bit like the wrong field (halfpicture) or when you have a cheap LCD TV) -> so I have to render my videos on version 4 and after that I import the MPEGS to DMF 5.
I use PAL.
Is Ulead not able to make a working version with a new release. The version 4 has less problems than version 5. The second problem above had also been a problem of version 2 of the German product.
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 10:18 pm, edited 1 time in total.
Rager01
Post by Rager01 »
maddrummer3301 wrote:Question, did you JOIN or do anything to the video(s) before rendering?
I did cut the AVI files (from one big sequence I made some sequences).
maddrummer3301
