Rendering Problems
LaughingOnTheInside
Rendering Problems
Post by LaughingOnTheInside »
Hello everyone
I'm trying to burn a pretty sizable DVD- its about 7.9 GB of data and I'm burning it onto a dual layer DVD. For this DVD, I've set up chapters and menus and such, but whenever I start to try and burn it, it works for about 2 hours and gets about halfway through rendering the menu transitions and then crashes.
I have tried changing everything I can think of to stop it from crashing, but nothing seems to help. I know my computer will burn DVDs like this, because I have burned a couple of them before, though never as big as this one.
I have no idea what I am doing wrong, or how I can fix it
I know I havent given much information here, but thats mostly because I am new to this process and this program and I am not sure what information would be helpful, so let me know what you need and I'll post it
Thank you so much in advance!
LaughingOnTheInside
sorry- I left out file formats and such
All of the files are in MPG-2 format, though I did try it a couple of times with the files in .avi format thinking that might help, but it didnt
I'm also using NTSC
Post by Black Lab »
You say it is "crashing". Are you getting any error messages?
You also say you have burned other DVDs in the past, but you don't really say if it was with VideoStudio. Have you successfully burned them with VS?
If this is your first project with VS, you may want to try burning a much smaller project first (might be easier trying to weed out what is wrong).
Also, try burning to a DVD folder instead of a disc and see what happens.
One other thing, try burning it without a menu. As I've discovered (see my post http://phpbb.ulead.com.tw/EN/viewtopic.php?t=17274) sometimes that can be a problem if the wrong parameters are selected.
DVDDoug
Moderator
Post by DVDDoug »
It does sound like a corrupt-file problem. It can be hard to tell, because a corrupt file can sometimes play back OK, but cause trouble when it's re-coded or re-remultiplexed.
All of the files are in MPG-2 format, though I did try it a couple of times with the files in .avi format...
Is that DV-AVI? (13GB per hour?) AVI doesn't tell the whole story. AVI files can contain video in almost any compression format. DV is the most trouble-free format.
I'm trying to burn a pretty sizable DVD- its about 7.9 GB of data..
The size of your original files may be different from the space required on the DVD if the format or bitrate is different from your project settings. What's the playing time?
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
LaughingOnTheInside
when i say "crashing" I mean the little windows window comes up that say "Ulead VideoStudio has performed an error and must be shut down. Would you like to send microsoft and error repot telling them about this problem?"
When i said I had burned other DVDs like this in the past, i meant with VideoStudio 10+ - sorry, i should have been more specific
I would love to try and burn a smaller project, but I'm doing this for a school project and I need it all together
I have been telling it to burn to a DVD folder along with burning to the DVD, but I never tried doing just the folder by itself- I will try that- Thanks
Again, since I'm doing this project, I need a menu, so unfortunately burning without a menu is not an option for me
LaughingOnTheInside
I tried converting some of my files that were causing me problems and they converted OK, but I dont know if that means anything
I tried it both uncompressed and in the DV format- neither works
I'm basing my 7.9 GB estimate on the total that VidoStudio gave me at the bottom of the creat disc wizard, but playing time is about 2 hours and 15 minutes
LaughingOnTheInside
Ok, so I tried tell it to just make DVD folders, and it still crashed
But, I got a copy of the error message this time, but its too big to be posted
I'll post the bottom part of it that will fit (because I'm thinking thats where the error woulld be), and if you want more, I can give it to you, but it looks a lot like its more of the same
anyway, here it is
<MATCHING_FILE NAME="uRenderS.dll" SIZE="126976" CHECKSUM="0x409AEC4D" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="uRenderS DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uRenderS.DLL" INTERNAL_NAME="uRenderS" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="06/30/2006 09:52:09" UPTO_LINK_DATE="06/30/2006 09:52:09" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uShadow.dll" SIZE="36864" CHECKSUM="0x727F76BE" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 15:22:19" UPTO_LINK_DATE="03/06/2006 15:22:19" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uSmartMultiTrim.dll" SIZE="49152" CHECKSUM="0x15282E76" BIN_FILE_VERSION="2.0.0.2" BIN_PRODUCT_VERSION="2.0.0.2" PRODUCT_VERSION="2, 0, 0, 2" FILE_DESCRIPTION="uSmartMultiTrim DLL" COMPANY_NAME="Ulead System" PRODUCT_NAME="uSmartMultiTrim Dynamic Link Library" FILE_VERSION="2, 0, 0, 2" ORIGINAL_FILENAME="uSmartMultiTrim.DLL" INTERNAL_NAME="uSmartMultiTrim" LEGAL_COPYRIGHT="Copyright (C) 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.2" UPTO_BIN_PRODUCT_VERSION="2.0.0.2" LINK_DATE="03/06/2006 15:38:41" UPTO_LINK_DATE="03/06/2006 15:38:41" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="uSmartSndMgr.dll" SIZE="53248" CHECKSUM="0xC6CA010E" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uSmartSndMgr DLL" COMPANY_NAME="" PRODUCT_NAME="uSmartSndMgr Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uSmartSndMgr.DLL" INTERNAL_NAME="uSmartSndMgr" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:38:20" UPTO_LINK_DATE="03/06/2006 15:38:20" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="uSmartSndMgrRC.dll" SIZE="24576" CHECKSUM="0xBD4CCD5E" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uSmartSndMgrRC DLL" COMPANY_NAME="" PRODUCT_NAME="uSmartSndMgrRC Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uSmartSndMgrRC.DLL" INTERNAL_NAME="uSmartSndMgrRC" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:38:17" UPTO_LINK_DATE="03/06/2006 15:38:17" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uSurround.dll" SIZE="24576" CHECKSUM="0xB0291E27" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uSurround DLL" COMPANY_NAME="" PRODUCT_NAME="uSurround Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uSurround.DLL" INTERNAL_NAME="uSurround" LEGAL_COPYRIGHT="Copyright (C) 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 14:59:14" UPTO_LINK_DATE="03/06/2006 14:59:14" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="uTextCfg.dll" SIZE="28672" CHECKSUM="0xEDA86FB0" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uTextCfg DLL" COMPANY_NAME="" PRODUCT_NAME="uTextCfg Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uTextCfg.DLL" INTERNAL_NAME="uTextCfg" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:41:59" UPTO_LINK_DATE="03/06/2006 15:41:59" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uTextTool.dll" SIZE="114688" CHECKSUM="0x73F881BB" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uTextTool DLL" COMPANY_NAME="" PRODUCT_NAME="uTextTool Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uTextTool.DLL" INTERNAL_NAME="uTextTool" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="07/25/2006 06:59:28" UPTO_LINK_DATE="07/25/2006 06:59:28" VER_LANGUAGE="Italian (Italy) [0x410]" />
<MATCHING_FILE NAME="uTextToolRc.dll" SIZE="40960" CHECKSUM="0xA459A141" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uTextToolRc DLL" COMPANY_NAME="" PRODUCT_NAME="uTextToolRc Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uTextToolRc.DLL" INTERNAL_NAME="uTextToolRc" LEGAL_COPYRIGHT="Copyright (C) 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:42:42" UPTO_LINK_DATE="03/06/2006 15:42:42" VER_LANGUAGE="Italian (Italy) [0x410]" />
<MATCHING_FILE NAME="uTextUser.dll" SIZE="118784" CHECKSUM="0xCB58C943" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uTextUser DLL" COMPANY_NAME="" PRODUCT_NAME="uTextUser Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uTextUser.DLL" INTERNAL_NAME="uTextUser" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="06/30/2006 09:52:01" UPTO_LINK_DATE="06/30/2006 09:52:01" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uTimeCode.dll" SIZE="28672" CHECKSUM="0xA3DE0F33" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uTimeCode DLL" COMPANY_NAME="" PRODUCT_NAME="uTimeCode Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uTimeCode.DLL" INTERNAL_NAME="uTimeCode" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="06/30/2006 09:51:31" UPTO_LINK_DATE="06/30/2006 09:51:31" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="Utmpmgr.dll" SIZE="32768" CHECKSUM="0xAE1ADA02" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="TempMgr DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="TempMgr.DLL" INTERNAL_NAME="TempMgr" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:36:47" UPTO_LINK_DATE="03/06/2006 15:36:47" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uTuner.dll" SIZE="40960" CHECKSUM="0x2F7F76F2" BIN_FILE_VERSION="1.0.1.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead TV tuner module to control TV tuner function." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, DVD MovieFactory, InstaMedia." FILE_VERSION="1.0.1.0" ORIGINAL_FILENAME="uTuner.dll" INTERNAL_NAME="TV tuner control module" LEGAL_COPYRIGHT="Copyright (c)2004-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.1.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:12:57" UPTO_LINK_DATE="03/06/2006 15:12:57" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvAudVUCtrl.dll" SIZE="90112" CHECKSUM="0xA498F2DA" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead Audio Volumn control module to control recorded audio." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, InstaMedia, Video@Home." FILE_VERSION="2.0.0.0" ORIGINAL_FILENAME="uvAudVUCtrl.dll" INTERNAL_NAME="Audio Source Volumn control" LEGAL_COPYRIGHT="Copyright (c)2003-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:12:50" UPTO_LINK_DATE="03/06/2006 15:12:50" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvBase.dll" SIZE="28672" CHECKSUM="0x9B9CFDBA" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="BASE LIBRARY" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="U32BASE.DLL" INTERNAL_NAME="U32BASE" LEGAL_COPYRIGHT="Copyright (c)1992-2002. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 14:59:44" UPTO_LINK_DATE="03/06/2006 14:59:44" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvCapMainDlg.dll" SIZE="159744" CHECKSUM="0x839F8E66" BIN_FILE_VERSION="3.0.1.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead Capture Settings Module." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro, DVD MovieFactory, InstaMedia, Video@Home, Video ToolBox." FILE_VERSION="3.0.1.0" ORIGINAL_FILENAME="uvCapMainDlg.dll" INTERNAL_NAME="Capture Settings dialog box module." LEGAL_COPYRIGHT="Copyright (c)2003-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.1.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:13:28" UPTO_LINK_DATE="03/06/2006 15:13:28" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvCapModuleNotify.dll" SIZE="28672" CHECKSUM="0x6090DEE7" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead COM based Capture Notify Module." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, Video ToolBox." FILE_VERSION="2.0.0.0" ORIGINAL_FILENAME="uvCapModuleNotify.dll" INTERNAL_NAME="COM Based Capture Notify Module" LEGAL_COPYRIGHT="Copyright (c)2004-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:12:09" UPTO_LINK_DATE="03/06/2006 15:12:09" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvCaptureModule.dll" SIZE="77824" CHECKSUM="0xF01928F" BIN_FILE_VERSION="2.0.0.1" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead COM based Capture Module." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, Video ToolBox." FILE_VERSION="2.0.0.1" ORIGINAL_FILENAME="uvCaptureModule.dll" INTERNAL_NAME="COM Based Capture Module" LEGAL_COPYRIGHT="Copyright (c)2004-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.1" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:12:16" UPTO_LINK_DATE="03/06/2006 15:12:16" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvCaptureRC.dll" SIZE="28672" CHECKSUM="0xB11CD9FC" BIN_FILE_VERSION="3.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Resource File for Advanced Capture Module." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro, DVD MovieFactory, InstaMedia, Video@Home, Video ToolBox." FILE_VERSION="3.0.0.0" ORIGINAL_FILENAME="uvCaptureRC.dll" INTERNAL_NAME="Advanced Capture Module RC file." LEGAL_COPYRIGHT="Copyright (c)2002-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:12:11" UPTO_LINK_DATE="03/06/2006 15:12:11" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvdetecthw.exe" SIZE="24576" CHECKSUM="0x3EBA0B16" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uvdetecthw MFC Application" COMPANY_NAME="" PRODUCT_NAME="uvdetecthw Application" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uvdetecthw.EXE" INTERNAL_NAME="uvdetecthw" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:57:18" UPTO_LINK_DATE="03/06/2006 15:57:18" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvDeviceSyncMgr.dll" SIZE="32768" CHECKSUM="0x1FB8CBB8" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uvDeviceSyncMgr DLL" COMPANY_NAME="" PRODUCT_NAME="uvDeviceSyncMgr Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uvDeviceSyncMgr.DLL" INTERNAL_NAME="uvDeviceSyncMgr" LEGAL_COPYRIGHT="Copyright (C) 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:58:33" UPTO_LINK_DATE="03/06/2006 15:58:33" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="uvDSBase.dll" SIZE="28672" CHECKSUM="0xAFB4684E" BIN_FILE_VERSION="4.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="4.0.0.0" FILE_DESCRIPTION="Ulead DirectShow utility base module." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro, DVD MovieFactory, InstaMedia, Video@Home, Video ToolBox." FILE_VERSION="4.0.0.0" ORIGINAL_FILENAME="uvDSBase.dll" INTERNAL_NAME="DirectShow utility base module" LEGAL_COPYRIGHT="Copyright (c)2002-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:11:58" UPTO_LINK_DATE="03/06/2006 15:11:58" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvDV.dll" SIZE="102400" CHECKSUM="0xD48E0105" BIN_FILE_VERSION="6.0.0.0" BIN_PRODUCT_VERSION="6.0.0.0" PRODUCT_VERSION="6.0" FILE_DESCRIPTION="BASE LIBRARY" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="6.0" ORIGINAL_FILENAME="U32BASE.DLL" INTERNAL_NAME="U32BASE" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.0" UPTO_BIN_PRODUCT_VERSION="6.0.0.0" LINK_DATE="03/06/2006 14:59:58" UPTO_LINK_DATE="03/06/2006 14:59:58" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uVeCfg.dll" SIZE="28672" CHECKSUM="0x37636CF" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uVeCfg DLL" COMPANY_NAME="" PRODUCT_NAME="uVeCfg Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uVeCfg.DLL" INTERNAL_NAME="uVeCfg" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:49:49" UPTO_LINK_DATE="03/06/2006 15:49:49" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvFieldDetect.dll" SIZE="32768" CHECKSUM="0xA25D02EC" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead Field type detection module for analog device." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro, DVD MovieFactory." FILE_VERSION="2.0.0.0" ORIGINAL_FILENAME="uvFieldDetect.dll" INTERNAL_NAME="Field Order detection module" LEGAL_COPYRIGHT="Copyright (c)2003-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:13:32" UPTO_LINK_DATE="03/06/2006 15:13:32" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvgrc.dll" SIZE="32768" CHECKSUM="0x4BE9CB91" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="uvgrc DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvgrc.DLL" INTERNAL_NAME="uvgrc" LEGAL_COPYRIGHT="Copyright (C) 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 14:57:37" UPTO_LINK_DATE="03/06/2006 14:57:37" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uVideoTool.dll" SIZE="32768" CHECKSUM="0x637B4474" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uVideoTool DLL" COMPANY_NAME="" PRODUCT_NAME="uVideoTool Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uVideoTool.DLL" INTERNAL_NAME="uVideoTool" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:37:25" UPTO_LINK_DATE="03/06/2006 15:37:25" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uVIOWrap.dll" SIZE="106496" CHECKSUM="0x9A9A488C" BIN_FILE_VERSION="3.6.12.18" BIN_PRODUCT_VERSION="3.6.12.18" PRODUCT_VERSION="3.6.12.18" FILE_DESCRIPTION="uVIOWrap DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="uVIOWrap Dynamic Link Library" FILE_VERSION="3.6.12.18" ORIGINAL_FILENAME="uVIOWrap.DLL" INTERNAL_NAME="uVIOWrap" LEGAL_COPYRIGHT="Copyright (c)2000-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.12.18" UPTO_BIN_PRODUCT_VERSION="3.6.12.18" LINK_DATE="03/06/2006 15:41:13" UPTO_LINK_DATE="03/06/2006 15:41:13" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uVioWrapRC.dll" SIZE="16384" CHECKSUM="0xD7A8D62" BIN_FILE_VERSION="3.3.0.1" BIN_PRODUCT_VERSION="3.3.0.1" PRODUCT_VERSION="3.3.0.1" FILE_DESCRIPTION="uVIOWrapRC.rc" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="uVioWrapRC Dynamic Link Library" FILE_VERSION="3.3.0.1" ORIGINAL_FILENAME="uVioWrapRC.dll" INTERNAL_NAME="uVIOWrapRC" LEGAL_COPYRIGHT="Copyright (c)2000-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.3.0.1" UPTO_BIN_PRODUCT_VERSION="3.3.0.1" LINK_DATE="03/06/2006 15:41:13" UPTO_LINK_DATE="03/06/2006 15:41:13" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvipl.dll" SIZE="20480" CHECKSUM="0x8E40ED88" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x1" LINK_DATE="09/05/2005 15:07:09" UPTO_LINK_DATE="09/05/2005 15:07:09" />
<MATCHING_FILE NAME="uviplA6.dll" SIZE="688128" CHECKSUM="0xDA7C2824" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x1" LINK_DATE="09/05/2005 15:07:13" UPTO_LINK_DATE="09/05/2005 15:07:13" />
<MATCHING_FILE NAME="uviplM6.dll" SIZE="663552" CHECKSUM="0xFC45472C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x1" LINK_DATE="09/05/2005 15:07:12" UPTO_LINK_DATE="09/05/2005 15:07:12" />
<MATCHING_FILE NAME="uviplP6.dll" SIZE="647168" CHECKSUM="0x406A41F7" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x1" LINK_DATE="09/05/2005 15:07:11" UPTO_LINK_DATE="09/05/2005 15:07:11" />
<MATCHING_FILE NAME="uviplPX.dll" SIZE="712704" CHECKSUM="0xCDB616B8" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x1" LINK_DATE="09/05/2005 15:07:10" UPTO_LINK_DATE="09/05/2005 15:07:10" />
<MATCHING_FILE NAME="uviplW7.dll" SIZE="708608" CHECKSUM="0x414E9A6" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x1" LINK_DATE="09/05/2005 15:07:14" UPTO_LINK_DATE="09/05/2005 15:07:14" />
<MATCHING_FILE NAME="uvipp.dll" SIZE="2711552" CHECKSUM="0x6D066B43" BIN_FILE_VERSION="7.2.0.0" BIN_PRODUCT_VERSION="7.2.0.0" PRODUCT_VERSION="7.2" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead MediaStudioPro" FILE_VERSION="7.2" ORIGINAL_FILENAME="uvipp.dll" INTERNAL_NAME="uvipp" LEGAL_COPYRIGHT="Copyright (c)1992-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="7.2.0.0" UPTO_BIN_PRODUCT_VERSION="7.2.0.0" LINK_DATE="09/05/2005 15:07:06" UPTO_LINK_DATE="09/05/2005 15:07:06" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvMixerControler.dll" SIZE="32846" CHECKSUM="0x72BBF2C9" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uvMixerControler DLL" COMPANY_NAME="" PRODUCT_NAME="uvMixerControler Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uvMixerControler.DLL" INTERNAL_NAME="uvMixerControler" LEGAL_COPYRIGHT="Copyright (C) 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:56:53" UPTO_LINK_DATE="03/06/2006 15:56:53" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="uvMP4Drv.dll" SIZE="139264" CHECKSUM="0xEBECA6D3" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Ulead MPEG-4 vio driver" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvMP4Drv.dll" INTERNAL_NAME="uvMP4Drv" LEGAL_COPYRIGHT="Copyright (c)1992-2002. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="07/26/2006 07:22:45" UPTO_LINK_DATE="07/26/2006 07:22:45" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvMP4SEPA.dll" SIZE="36864" CHECKSUM="0x365EE3D6" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Ulead MPEG-4 Smart Render (DTR)" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvMP4SEPA.dll" INTERNAL_NAME="uvMP4SEPA" LEGAL_COPYRIGHT="Copyright (c)2002-2003. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:06:43" UPTO_LINK_DATE="03/06/2006 15:06:43" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvMPEG2.dll" SIZE="274432" CHECKSUM="0x5BCF1141" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Ulead MPEG codec" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvmpeg2.dll" INTERNAL_NAME="uvmpeg2" LEGAL_COPYRIGHT="Copyright (c)1992-2002. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="09/13/2006 04:50:11" UPTO_LINK_DATE="09/13/2006 04:50:11" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvMPEGRO.dll" SIZE="106496" CHECKSUM="0xBC1FAE0C" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Ulead MPEG codec" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead Systems Read Only MPEG VIO Driver" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvMPEGRO.dll" INTERNAL_NAME="uvMPEGRO" LEGAL_COPYRIGHT="Copyright (C) 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:07:31" UPTO_LINK_DATE="03/06/2006 15:07:31" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvMPEGWO.dll" SIZE="45056" CHECKSUM="0x3D2419A" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="uvMPEGWO DLL" COMPANY_NAME="" PRODUCT_NAME="Ulead Systems Write Only MPEG VIO Driver" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvMPEGWO.DLL" INTERNAL_NAME="uvMPEGWO" LEGAL_COPYRIGHT="Copyright (C) 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:07:39" UPTO_LINK_DATE="03/06/2006 15:07:39" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvPL.exe" SIZE="36864" CHECKSUM="0x83B60CFA" BIN_FILE_VERSION="9.0.0.0" BIN_PRODUCT_VERSION="9.0.0.0" PRODUCT_VERSION="9.0" FILE_DESCRIPTION="Ulead VideoStudio" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="9.0" ORIGINAL_FILENAME="Vstudio.EXE" INTERNAL_NAME="Ulead VideoStudio" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.0.0.0" UPTO_BIN_PRODUCT_VERSION="9.0.0.0" LINK_DATE="03/06/2006 16:52:15" UPTO_LINK_DATE="03/06/2006 16:52:15" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvPlay.dll" SIZE="106496" CHECKSUM="0x6277BB32" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0" FILE_DESCRIPTION="BASE LIBRARY" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0" ORIGINAL_FILENAME="U32BASE.DLL" INTERNAL_NAME="U32BASE" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:00:13" UPTO_LINK_DATE="03/06/2006 15:00:13" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvSEPA.dll" SIZE="151552" CHECKSUM="0x5A178295" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="MPEG Smart Render II" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="MPEG Smart Render II" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvSEPA.dll" INTERNAL_NAME="uvSEPA" LEGAL_COPYRIGHT="Copyright (c)2002-2003. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="07/10/2006 10:59:30" UPTO_LINK_DATE="07/10/2006 10:59:30" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvTeletextModule.dll" SIZE="61440" CHECKSUM="0x48553384" BIN_FILE_VERSION="1.0.0.3" BIN_PRODUCT_VERSION="1.0.0.3" PRODUCT_VERSION="0" FILE_DESCRIPTION="Teletext Module Dll" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead Produce" FILE_VERSION="1.0.0.2" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)2004-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.3" UPTO_BIN_PRODUCT_VERSION="1.0.0.3" LINK_DATE="03/06/2006 15:13:36" UPTO_LINK_DATE="03/06/2006 15:13:36" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvUser.dll" SIZE="208896" CHECKSUM="0x22258B1D" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uvUser DLL" COMPANY_NAME="" PRODUCT_NAME="uvUser Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uvUser.DLL" INTERNAL_NAME="uvUser" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:56:43" UPTO_LINK_DATE="03/06/2006 15:56:43" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="UvUserRC.dll" SIZE="147456" CHECKSUM="0x736AD2DF" BIN_FILE_VERSION="8.0.0.1" BIN_PRODUCT_VERSION="8.0.0.1" PRODUCT_VERSION="8, 0, 0, 1" FILE_DESCRIPTION="UvUserRC DLL" COMPANY_NAME="" PRODUCT_NAME="UvUserRC Dynamic Link Library" FILE_VERSION="8, 0, 0, 1" ORIGINAL_FILENAME="UvUserRC.DLL" INTERNAL_NAME="UvUserRC" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.1" UPTO_BIN_PRODUCT_VERSION="8.0.0.1" LINK_DATE="03/06/2006 15:56:36" UPTO_LINK_DATE="03/06/2006 15:56:36" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="uvVIOCapShareModuleRC.dll" SIZE="24576" CHECKSUM="0x4A9EFFA8" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="2.0.0.0" PRODUCT_VERSION="2.0.0.0" FILE_DESCRIPTION="uvVIOCapShareModuleRC DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead Video ToolBox" FILE_VERSION="2.0.0.0" ORIGINAL_FILENAME="uvVIOCapShareModuleRC.DLL" INTERNAL_NAME="uvVIOCapShareModuleRC" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="2.0.0.0" LINK_DATE="03/06/2006 14:57:57" UPTO_LINK_DATE="03/06/2006 14:57:57" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvWMEProfile.dll" SIZE="49152" CHECKSUM="0x4E9726C1" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="2.0.0.0" PRODUCT_VERSION="8, 0, 0, 0" COMPANY_NAME="Ulead Systems, Inc." FILE_VERSION="8, 0, 0, 0" ORIGINAL_FILENAME="uvWMEProfile.dll" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="2.0.0.0" LINK_DATE="03/06/2006 14:58:05" UPTO_LINK_DATE="03/06/2006 14:58:05" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvwprjio.dll" SIZE="24576" CHECKSUM="0x7F3FEDF4" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="uvwprjio DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="uvwprjio.DLL" INTERNAL_NAME="uvwprjio" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:38:22" UPTO_LINK_DATE="03/06/2006 15:38:22" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uvwtxt.dll" SIZE="65536" CHECKSUM="0xE2F6B245" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="uvwtxt DLL" COMPANY_NAME="" PRODUCT_NAME="uvwtxt Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="uvwtxt.DLL" INTERNAL_NAME="uvwtxt" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/06/2006 15:42:45" UPTO_LINK_DATE="03/06/2006 15:42:45" VER_LANGUAGE="Italian (Italy) [0x410]" />
<MATCHING_FILE NAME="uwUpdate.dll" SIZE="36864" CHECKSUM="0x61FF21D0" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="uwUpdate DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="uwUpdate.DLL" INTERNAL_NAME="uwUpdate" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 15:22:36" UPTO_LINK_DATE="03/06/2006 15:22:36" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="Vcvrt32.dll" SIZE="45056" CHECKSUM="0x16278F08" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="BASE LIBRARY" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="U32BASE.DLL" INTERNAL_NAME="U32BASE" LEGAL_COPYRIGHT="Copyright (c)1992-2002. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 14:59:21" UPTO_LINK_DATE="03/06/2006 14:59:21" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="Vepb40.dll" SIZE="32768" CHECKSUM="0x8950F51B" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="BASE LIBRARY" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="U32BASE.DLL" INTERNAL_NAME="U32BASE" LEGAL_COPYRIGHT="Copyright (c)1992-2002. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 14:59:41" UPTO_LINK_DATE="03/06/2006 14:59:41" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="Veui32.dll" SIZE="167936" CHECKSUM="0xB512A177" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="06/30/2006 09:51:52" UPTO_LINK_DATE="06/30/2006 09:51:52" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="veui32rc.dll" SIZE="520192" CHECKSUM="0x12ACDF01" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="3-D custom controls support module" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="UL3DUI.DLL" INTERNAL_NAME="UL3DUI" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x1" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:10:26" UPTO_LINK_DATE="03/06/2006 15:10:26" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="Vft32.dll" SIZE="90112" CHECKSUM="0xE2C44FB0" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:26:00" UPTO_LINK_DATE="03/06/2006 15:26:00" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="Vft32rc.dll" SIZE="94208" CHECKSUM="0xFA4C544D" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:25:58" UPTO_LINK_DATE="03/06/2006 15:25:58" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="vftatrc.dll" SIZE="405504" CHECKSUM="0xA414B398" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="06/30/2006 10:06:29" UPTO_LINK_DATE="06/30/2006 10:06:29" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="vftbase.dll" SIZE="57344" CHECKSUM="0xE39BBFCB" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:27:58" UPTO_LINK_DATE="03/06/2006 15:27:58" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="vftrc.dll" SIZE="299008" CHECKSUM="0x1B07718E" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="07/13/2006 04:43:42" UPTO_LINK_DATE="07/13/2006 04:43:42" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VfwPluin.dll" SIZE="32768" CHECKSUM="0x3869CD9" BIN_FILE_VERSION="9.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead VFW Capture Plug-in for AVI file." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro, DVD MovieFactory." FILE_VERSION="9.0.0.0" ORIGINAL_FILENAME="VfwPluin.dll" INTERNAL_NAME="VideoForWindow AVI Capture plug-in" LEGAL_COPYRIGHT="Copyright (c)1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:17:11" UPTO_LINK_DATE="03/06/2006 15:17:11" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VfwUleadMpegCap.dll" SIZE="45056" CHECKSUM="0x34DD9D2" BIN_FILE_VERSION="9.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead VFW Capture Plug-in for MPEG1/2 file." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro, DVD MovieFactory." FILE_VERSION="9.0.0.0" ORIGINAL_FILENAME="VfwUleadMpegCap.dll" INTERNAL_NAME="VideoForWindow MPEG1/2 Capture plug-in" LEGAL_COPYRIGHT="Copyright (c)1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:17:14" UPTO_LINK_DATE="03/06/2006 15:17:14" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VFX32.dll" SIZE="69632" CHECKSUM="0xAF97EB27" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Transition Effect Shared DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="VFX.DLL" INTERNAL_NAME="VFX" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10001" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:29:28" UPTO_LINK_DATE="03/06/2006 15:29:28" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VfxATRC.dll" SIZE="167936" CHECKSUM="0x9081234A" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="effect plug-in DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="ALBUM.VFX" INTERNAL_NAME="Flip-Album" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:31:36" UPTO_LINK_DATE="03/06/2006 15:31:36" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VfxIMGRC.dll" SIZE="618496" CHECKSUM="0x2055DD89" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/06/2006 15:31:38" UPTO_LINK_DATE="03/06/2006 15:31:38" />
<MATCHING_FILE NAME="vfxrc.dll" SIZE="45056" CHECKSUM="0xB251EC30" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/06/2006 15:29:29" UPTO_LINK_DATE="03/06/2006 15:29:29" />
<MATCHING_FILE NAME="VFX_MMX.DLL" SIZE="24576" CHECKSUM="0x6E915A0" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="effect plug-in DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="VFX_MMX.DLL" INTERNAL_NAME="VFX_MMX" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10001" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:29:33" UPTO_LINK_DATE="03/06/2006 15:29:33" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VideoAnalysis.dll" SIZE="61440" CHECKSUM="0xE5B90A76" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/06/2006 15:54:06" UPTO_LINK_DATE="03/06/2006 15:54:06" />
<MATCHING_FILE NAME="VioRC.dll" SIZE="327680" CHECKSUM="0xD065FE19" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="BASE LIBRARY" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="U32BASE.DLL" INTERNAL_NAME="U32BASE" LEGAL_COPYRIGHT="Copyright (c)1992-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 14:59:23" UPTO_LINK_DATE="03/06/2006 14:59:23" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VR_MANGR.dll" SIZE="520192" CHECKSUM="0x2B69FF22" BIN_FILE_VERSION="1.3.0.29" BIN_PRODUCT_VERSION="1.3.0.29" PRODUCT_VERSION="1, 3, 0, 29" FILE_DESCRIPTION="VR_MANGR Module" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="DVD-VR Module" FILE_VERSION="1, 3, 0, 29" ORIGINAL_FILENAME="VR_MANGR.DLL" INTERNAL_NAME="VR_MANGR" LEGAL_COPYRIGHT="Copyright 1992-2003. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.3.0.29" UPTO_BIN_PRODUCT_VERSION="1.3.0.29" LINK_DATE="02/23/2006 07:43:25" UPTO_LINK_DATE="02/23/2006 07:43:25" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VR_MOVIE.dll" SIZE="139264" CHECKSUM="0x7D2350D" BIN_FILE_VERSION="1.0.3.17" BIN_PRODUCT_VERSION="1.0.3.17" PRODUCT_VERSION="1, 0, 3, 17" FILE_DESCRIPTION="VR_MOVIE Module" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="DVD-VR Module" FILE_VERSION="1, 0, 3, 17" ORIGINAL_FILENAME="VR_MOVIE.DLL" INTERNAL_NAME="VR_MOVIE" LEGAL_COPYRIGHT="Copyright 1992-2003. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.3.17" UPTO_BIN_PRODUCT_VERSION="1.0.3.17" LINK_DATE="03/30/2005 07:53:45" UPTO_LINK_DATE="03/30/2005 07:53:45" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="VSTempTrans.dll" SIZE="94208" CHECKSUM="0x563E86F0" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="VSTempTrans DLL" COMPANY_NAME="" PRODUCT_NAME="VSTempTrans Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="VSTempTrans.DLL" INTERNAL_NAME="VSTempTrans" LEGAL_COPYRIGHT="Copyright (C) 2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="06/30/2006 09:55:58" UPTO_LINK_DATE="06/30/2006 09:55:58" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="vstudio.exe" SIZE="1794048" CHECKSUM="0xFF10755E" BIN_FILE_VERSION="10.0.0.0" BIN_PRODUCT_VERSION="10.0.0.0" PRODUCT_VERSION="10.0" FILE_DESCRIPTION="Ulead VideoStudio" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="10.0" ORIGINAL_FILENAME="Vstudio.EXE" INTERNAL_NAME="Ulead VideoStudio" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.0.0.0" UPTO_BIN_PRODUCT_VERSION="10.0.0.0" LINK_DATE="09/12/2006 11:50:06" UPTO_LINK_DATE="09/12/2006 11:50:06" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="wcsRWUFO.dll" SIZE="24576" CHECKSUM="0x121474A5" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="wcsRWUFO DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="wcsRWUFO.DLL" INTERNAL_NAME="wcsRWUFO" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 15:39:25" UPTO_LINK_DATE="03/06/2006 15:39:25" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="WMFCap.dll" SIZE="196608" CHECKSUM="0xFB46EF7" BIN_FILE_VERSION="3.0.0.0" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.0.0.0" FILE_DESCRIPTION="Ulead DirectShow Capture Plug-in for WMV file." COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio, MediaStudio Pro." FILE_VERSION="3.0.0.0" ORIGINAL_FILENAME="WMFCap.dll" INTERNAL_NAME="DirectShow WMV Capture plug-in" LEGAL_COPYRIGHT="Copyright (c)2002-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="03/06/2006 15:17:38" UPTO_LINK_DATE="03/06/2006 15:17:38" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="wWebComp.dll" SIZE="122880" CHECKSUM="0x402667CD" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="wWebComp DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="wWebComp.DLL" INTERNAL_NAME="wWebComp" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 15:39:32" UPTO_LINK_DATE="03/06/2006 15:39:32" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="EIO\EIO.DLL" SIZE="53248" CHECKSUM="0xF63E66C0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/06/2006 15:20:11" UPTO_LINK_DATE="03/06/2006 15:20:11" />
<MATCHING_FILE NAME="EIO\VSTRES.DLL" SIZE="32768" CHECKSUM="0x1C5263F2" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c)1992-2004. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:20:25" UPTO_LINK_DATE="03/06/2006 15:20:25" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\FIORC.dll" SIZE="81920" CHECKSUM="0x94F6BEA0" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 14:54:56" UPTO_LINK_DATE="03/06/2006 14:54:56" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\FIORC2.dll" SIZE="49152" CHECKSUM="0xDDFDCFA9" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 14:57:17" UPTO_LINK_DATE="03/06/2006 14:57:17" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\FPXLIB.DLL" SIZE="306688" CHECKSUM="0x68BF452" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="V1.0" FILE_DESCRIPTION="FPXLIB.DLL" COMPANY_NAME="" PRODUCT_NAME="Reference Implementation" FILE_VERSION="V1.0FC13" ORIGINAL_FILENAME="FPXLIB.DLL" INTERNAL_NAME="FPXLIB" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="02/04/1997 19:00:12" UPTO_LINK_DATE="02/04/1997 19:00:12" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\JPEGLIB.DLL" SIZE="95232" CHECKSUM="0x747CB129" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="01/29/1997 13:01:06" UPTO_LINK_DATE="01/29/1997 13:01:06" />
<MATCHING_FILE NAME="fio\PCDLIB32.DLL" SIZE="212480" CHECKSUM="0x613648C1" BIN_FILE_VERSION="3.0.0.0" BIN_PRODUCT_VERSION="3.0.0.0" PRODUCT_VERSION="3, 0, 0, 0" FILE_DESCRIPTION="PCDLIB32" COMPANY_NAME="Eastman Kodak" PRODUCT_NAME="Kodak Photo CD Access Developer Toolkit" FILE_VERSION="3, 0, 0, 0" ORIGINAL_FILENAME="PCDLIB32.dll" INTERNAL_NAME="PCDLIB32" LEGAL_COPYRIGHT="Eastman Kodak Company Copyright 1995" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="3.0.0.0" UPTO_BIN_PRODUCT_VERSION="3.0.0.0" LINK_DATE="06/21/1995 17:45:57" UPTO_LINK_DATE="06/21/1995 17:45:57" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\u32lzw.dll" SIZE="24576" CHECKSUM="0xC12C67DB" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="Image Editor" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="u32Lzw.DLL" INTERNAL_NAME="u32Lzw" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 14:54:43" UPTO_LINK_DATE="03/06/2006 14:54:43" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\u32Prj.dll" SIZE="65536" CHECKSUM="0x8E970177" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="UFO File I/O" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="U32UFO.FIO" INTERNAL_NAME="U32UFO" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 14:56:19" UPTO_LINK_DATE="03/06/2006 14:56:19" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\u32zlib.dll" SIZE="45056" CHECKSUM="0x1D5BB496" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="Image Editor" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="IEDIT.EXE" INTERNAL_NAME="IEDIT3" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 14:54:42" UPTO_LINK_DATE="03/06/2006 14:54:42" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="fio\uFioUtil.dll" SIZE="32768" CHECKSUM="0x7FDC9AB8" BIN_FILE_VERSION="11.0.0.0" BIN_PRODUCT_VERSION="11.0.0.0" PRODUCT_VERSION="11.0.0.0" FILE_DESCRIPTION="File I/O Utility" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead PhotoImpact" FILE_VERSION="11.0.0.0" ORIGINAL_FILENAME="UFIOUTIL.DLL" INTERNAL_NAME="UFIOUTIL" LEGAL_COPYRIGHT="Copyright (c) 1992-2005. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.0" UPTO_BIN_PRODUCT_VERSION="11.0.0.0" LINK_DATE="03/06/2006 14:54:39" UPTO_LINK_DATE="03/06/2006 14:54:39" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="motion_plug\Curve.dll" SIZE="176128" CHECKSUM="0x4C9FE086" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="curve DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="curve.DLL" INTERNAL_NAME="curve" LEGAL_COPYRIGHT="Copyright (C) 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:42:10" UPTO_LINK_DATE="03/06/2006 15:42:10" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="motion_plug\Drop.dll" SIZE="61440" CHECKSUM="0xC86A00D7" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Drop DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="Drop.DLL" INTERNAL_NAME="Drop" LEGAL_COPYRIGHT="Copyright (C) 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:42:14" UPTO_LINK_DATE="03/06/2006 15:42:14" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="motion_plug\Fade.dll" SIZE="65536" CHECKSUM="0x18A3320A" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Fade DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="Fade.DLL" INTERNAL_NAME="Fade" LEGAL_COPYRIGHT="Copyright (C) 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:42:18" UPTO_LINK_DATE="03/06/2006 15:42:18" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="motion_plug\Fly.dll" SIZE="188416" CHECKSUM="0x5737DC43" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="Fly DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="Fly.DLL" INTERNAL_NAME="Fly" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:42:27" UPTO_LINK_DATE="03/06/2006 15:42:27" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="motion_plug\PathAnim.dll" SIZE="143360" CHECKSUM="0x16A58129" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="PathAnim DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="PathAnim.DLL" INTERNAL_NAME="PathAnim" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:42:35" UPTO_LINK_DATE="03/06/2006 15:42:35" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="motion_plug\Popup.dll" SIZE="110592" CHECKSUM="0x8DF9DDF2" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="PathAnim DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="PathAnim.DLL" INTERNAL_NAME="PathAnim" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.0" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/06/2006 15:42:40" UPTO_LINK_DATE="03/06/2006 15:42:40" VER_LANGUAGE="Chinese (Taiwan) [0x404]" />
<MATCHING_FILE NAME="motion_plug\Turn.dll" SIZE="86016" CHECKSUM="0x53E010D5" BIN_FILE_VERSION="8.0.0.0" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0.0.0" FILE_DESCRIPTION="PathAnim DLL" COMPANY_NAME="Ulead Systems, Inc." PRODUCT_NAME="Ulead VideoStudio" FILE_VERSION="8.0.0.0" ORIGINAL_FILENAME="PathAnim.DLL" INTERNAL_NAME="PathAnim" LEGAL_COPYRIGHT="Copyright (c)1992-2001. Ulead Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_T
Post by Black Lab »
Will your project burn to a DVD folder if you do not include the menu? If so, see my post where I had a similar problem: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=17274.
LaughingOnTheInside
Post by LaughingOnTheInside »
yes, it turned out to work when I didn't use menus, so it looks like I had the same problem you did
Sorry for posting about this when the answer was already there!
