I wonder if anybody can help me to do a 3d picture in pictue.
What i am trying to do is to haver perspective in my picture in picture.
When i use 3d moving path it does not want to stay still.
So really what i want is to be able to put a picture in picture and be able to have the Y X Z motion.
Thanks for your help.
Bob
3d picture in picture
You need to set up the PiP so that the start and end keyframes contain the same parameters. With MSP8 you can do that using copy and paste.
To give it perspective without motion (i.e. turn it into a rapezoid instead of a rectangle), you need to adjust the corner points on the stretch marquee in the moving path dialog. Don't forget to do the copy/paste of the keyframes after you've got the perspective looking right on one of the keyframes.
If, by perspective, you mean the picture appearing to move out of the screen in the Z axis, you do that by adjusting the size of the PiP between keyframes. Don't forget to keep the apsect ration constant by checking the box at the bottom left.
