capture A/V severe sync problem, VS8
mikewillnot
Post by mikewillnot »
I'm capturing video from a DV camcorder, via firewire, I think using the recommended procedure settings (translated for VS-8), direct to AVI. The captured video has a severe A/V sync problem, a full minute or two out-of-sync. This problem is not on the original tape, only on the captured AVI. Any suggestions for troubleshooting would be GREATLY appreciated. Thanks.
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
Fill in your system details but for a start are you capturing to DV AVI type 1?
Some users have had trouble with DV AVI Type 2 as it is a little more resource intensive.
mikewillnot
Windows XP Professional
Pentium 4, 2.66 ghz
1.5 gb ram
VS 8.01.1000
Preferences:
Instant Playback
Instant playback target: Dual Head Device
Default field order: Frame Based
Image capture deinterlace - unchecked
Project settings:
NTSC drop frame 29.97
MS AVI files
24 bits, 720x480, 4:3, 29.97
Lower Field First
MainConcept DV Codec 2.0.4 -- type 2
DV Audio -- NTSC
48,000 khz, 16bit, stereo
Did I miss anything important?
lancecarr
ram: 12GB
Post by lancecarr »
I would try re-capturing using DV AVI Type 1.
Post by Black Lab »
Version 8 was notorious for out of sync problems. Just a horrible version. I would upgrade to v10. No OOS problems and many nice enhancements.
lancecarr
ram: 12GB
Post by lancecarr »
Hi Jeff,
Yes VS8 was a pig for OOS but that was at the conversion to MPEG point. The OP is getting OOS at the capture stage which would tend to suggest the computer is not quite making it on the DV AVI type 2.
mikewillnot, as well as re-capturing to type 1 also make sure you have every background program you can lay your hands on shut down and also freshly defragged hard drives.
Post by Black Lab »
You are quite right. :oops:
Hmm, maybe that's why my reading comprehension grades were not that good.
Post by Trevor Andrew »
As lancecarr has stated capture to dv- type 1.
From the capture window select DV as the capture format.
Dv should remain as the capture format and not Avi.
Select ‘options’ and select DV-Type 1
The captured files will be Avi.
This transfers the footage without re-coding.
What you have in the camera is what you get on the pc.
Trevor
mikewillnot
If you follow the procedure in this link
How to complete your system specifications in this forum
You will never have to enter all of that information again. We will simply be able to click this button Image
If you're still having out of synch issues please view:
From Camcorder to DVD with VideoStudio
