buring to disc question
ajcvideo
Post by ajcvideo »
trying to burn on a DVD an .m2p and a folder with some jpeg's. Tried burn now but .m2p does not play on home player but does on PC. I have no idea how to do it in DVDWS2. I have been using DVDWS2 for 3 years but only to burn .m2p.
Much Obliged,
Ara
heinz-oz
Post by heinz-oz »
How exactly did you burn this? Can you give an example of the DVD contents when viewed in WinExplorer?
Do you just have the Video_TS and Audio_TS folders or is there more?
ajcvideo
Post by ajcvideo »
Just got an answer. In advance settings you cann add a folder. I just burned successfully. I do have one more question, cann you add two folders or files?
To answer your question, I used burn now and did not have video or audio ts folders. I just copied to the disc, but all is fine now.
heinz-oz
Post by heinz-oz »
Must be a mighty good DVD player, mine wouldn't do it I'm sure.
Glad you worked it out. As long as you don't want to share it with others. :wink:
ajcvideo
Post by ajcvideo »
heinz-oz wrote:Must be a mighty good DVD player, mine wouldn't do it I'm sure.
I'm not sure what you mean about sharing but I'll try and share as much as I kmow. What is it that you want to know?
heinz-oz
Post by heinz-oz »
I was referring to your DVD. I don't think there would be too many DVD players that would be able to play a DVD disk as you describe, that's all. I have got one that plays jpeg images straight but daubt (never tried it) that it will play a straight mpeg file from the same disk.
ajcvideo
Post by ajcvideo »
heinz-oz wrote:I was referring to your DVD. I don't think there would be too many DVD players that would be able to play a DVD disk as you describe, that's all. I have got one that plays jpeg images straight but daubt (never tried it) that it will play a straight mpeg file from the same disk.
The only reason why I want to put the jpeg's on the disk is to give the client their pictures that I scanned for them for the photo montage. Nothing magical about what I was asking in my original post. Iam greatful that I got an answer on how to accomplish the task and for that I say thanks to all.
