I created the project in Adobe Premier 6.5
After I imported the project into Workshop 2.0 and burned it to a DVD, I played it in my DVD player and after a while the DVD freezes.
Can anyone help PLEASE!!!
DVD Freezes during playback after a certin point during.
It could simply be a bad DVD or a bad burn. Try burning another DVD. Try buirning at a slower speed, or "burn" a DVD to your hard drive by checking the box that says Create DVD Folders.
It could also be that your bitrate is a little too high.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Please give the mpg settings. It is quite likely you have the combined audio and video bitrates set higher than your player can handle, as DVDDoug says. This is a common mistake.
digitalstud
My DVD freezes during playback
I created a project in adobe 6.5 premier and after i burned it using workshop 2.0, it freezes after a few minutes of playback.
spec are
file format microfoft avi file-openDML
filesize-15,568,207 KBytes
frame rate-29.970 frames/sec
duration 4207.441 sec
data rate 1184.38 Kbps
Video
compression Panasonic DV codec type2
attributes 24 bits, 720x480
total frames 126,097 frames
Audio
compression PCM
attributes 48000 KHz 16 bit stereo
total sample 201,957,120
spec are
Video
Audio
compression PCM
- ram: 2 GB
- sound_card: Intel GMA 950
Re: My DVD freezes during playback
Does this relate to the original video (prior to editing) or the video that has been edited and passed to DVD workshop?digitalstud wrote:I created a project in adobe 6.5 premier and after i burned it using workshop 2.0, it freezes after a few minutes of playback.
spec are
Capture in DV (avi) and do all of your editing -cuts, transitions, titles so on and so forth. Then render it to a DVD compliant MPEG2 file.
Suggested MPEG 2 settings are listed here:
What bit rate settings should I use?
