PhotoImpact 12 doesn't work with 800x600 screen resolution
ttomomo
I always use 800x600 screen resolution because I need to wear my reading glass when I work with my PC. However PI12 cannot be initiated unless I change the resolution to 1024x768. Why?
heinz-oz
Caritoop
Caritoop
keenart
Xyzzy2
- motherboard: MSI Z77MA-G45
- processor: Intel i5-3570K
- ram: 8 GB
- Video Card: MSI R7770-2PMD1GD5 OC
- sound_card: Realtek 892
- Hard_Drive_Capacity: 6.25 TB
- Monitor/Display Make & Model: HP ZR24w
From system requirements:
X.
Code: Select all
True Color or Hi-Color display adapter with 1024x768 resolutions or higherX.
Caritoop
heinz-oz
I wouldn't hold my breath. I don't think they will be able to accomodate you. The basic requirement is for a display with 1024x768 or higher.
Whether you like it or not, I think you are stuck.
An old car doesn't run on unleaded petrol either. Maybe it's time to come out of last century's technology.
ttomomo
keenart
Caritoop
robains
I'm a developer, every dev shop I know works to minimum spec of 1024 x 768 unless they're working with PDAs or Smart Phone.
Find another product, don't buy this one if your really stubborn about working in 800 x 600. But keep in mind, even my 75 year old parents use 1024 x 768.
I don't see how you can work effectively at 800 x 600. But if you insist on this restriction there are plenty of other less powerful tools out there that you can use -- MS Paint perhaps. Considering this product is $50 and a used 15" LCD that does 1024 x 768 can be had for $40 on eBay, your stubborn attitude doesn't hold much influence.
Rob
Rob
What kind of arrogance do you display to people in wheel chairs?robains wrote:I'm a developer, every dev shop I know works to minimum spec of 1024 x 768 unless they're working with PDAs or Smart Phone.
Rob
The reason why I didn't go to PI 11 was because it, too, required 1024x768. I, like the original poster, cannot see the damn screen properly at anything finer than 800x600. And, even without downloading the TBYB version of PI 12, I won't be wasting my time looking at it.
I have to use VS9 at 1024x768 but it is really quite difficult, thank-you. I'll continue to plod along though because I do not use it everyday. PI10, on the other hand, is used several times a day.
I am glad that your 75 year old parents can use 1024x768. I'm about 10 years away from that milestone, have worn coke bottle bottom glasses since I was 12 and have few problems living in your 20/20 world.
Come into my world and see what it's like.
htchien
Everyone has his concerns.
My wife also use the PC in 800x600 resolution when we still use 15" LCD and she is now 31. Not only elders will need the low resolution.
However I solve the issue by using a 19" LCD with 1280x1024 resolution instead. Also use the large font in Windows so my wife can use the PC.
H.T.
H.T.
Ted (H.T.)
