I am using VS10.
Whenever I try to capture in MPEG2, I get the following message after stopping the capture:
"Capturing failed.
The file created is corrupted and usuable.
It will be automatically deleted."
It used to work before.
Failed Capture in MPEG2
heinz-oz
You think that's weird, try this one. After an electrical storm and a power outage (I wasn't home then) my internet PC, which is permanently on, was dead when I arrived home. Nothing special I thought, because I knew we had a short power outage.
When I tried to switch it on again, no action, it was just that, DEAD. I unplugged it to try it at a different location in the house as well as to open it up and check the power supply. The moment I had it removed from under my bench the phone rings. A little while later, I get back to it and plug it into a different power socket, on it comes, crikey! what was that?
To cut a long story short, I put it back where it came from, plugged it into the same power point, connected everything agin and it worked. That was more than a week ago and it hasn't missed a beat yet.
Go figure.
Go figure.
