From dmf_temp to dvd folders or iso files?!
shaka
Post by shaka »
Hi everyone!
I have a question very simple for you: so do you know a way to create dvd folders or an iso image file by the dmf_temp folder? Cause I tried to record a dvd, but I had an error from my hard disk when it was going to create the dvd folders...so, I would like to gain some time avoiding the converting process again!
Thank you for your answers in advance ^^
Touchstone_Pictures
Post by Touchstone_Pictures »
Download a free trial version of UltraIso,With this program you can make an iso file + you can do many many more Good luck .. :wink:
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 10:08 pm, edited 1 time in total.
shaka
Post by shaka »
maddrummer3301 wrote:You can't use the files because they are deleted when the program's finished and you click on OK. Besides, you had an error on the harddisk so I wouldn't trust those files anyway.
Next time if you use MF to burn with also check on "Create Dvd Folders". The process for burning will still be the same amount of time. Then you can reuse the dvd folders to burn another dvd, create an iso, or play the dvd from the harddisk.
I checked it, the error occurred when "create dvd folders" was acting...I think that my external hard disk turned off so MF didn't find the target to let the process happen! So there's no way to convert the dmf_temp in the video_ts folder... :(
Touchstone_Pictures
Shaka trust me you wont get an eror and the temp files are not erased if you dont close the program ,yust dont close the program minimize it,open UltraIso select the converted videos in the temp folder from dvd moviefactory and make it Iso .. :)
forkart
Post by forkart »
you also can try to use magiciso to create iso image from dmf_temp folder.
http://www.magiciso.com/
