With studio 10, I have no problem spitting audio from the video track on timeline. But after doing this, how can I reunite the two on the video track... a day or two later? Is splitting audio irreversable?
Also, what do I do when I need 3 audio tracks? On Studio 10 I find only two tracks for audio. Is there a trick I don't know about? Sorry for these simple questions, but I'm a slow learner.
Mike
Split audio from video track
Mike Warren
- motherboard: E7600 3.06 GHz 3.07 GHz
- processor: Intel Core 2 Duo CPU
- ram: 3.46 G Ram
- Video Card: Built into motherboard
- sound_card: Sound blaster Extreme X
- Hard_Drive_Capacity: 1250 G
- Monitor/Display Make & Model: Hanns.G, HDMI
Re: Split audio from video track
Mike Warren wrote:With studio 10, I have no problem spitting audio from the video track on timeline. But after doing this, how can I reunite the two on the video track... a day or two later? Is splitting audio irreversable? No just hit the mute button to return the video's audio. delete the split audio
Also, what do I do when I need 3 audio tracks? On Studio 10 I find only two tracks for audio. Is there a trick I don't know about? Sorry for these simple questions, but I'm a slow learner. There are only two audio tracks, if you need more, render the project to one file, then use the two tracks again.
Mike
blplhp
- motherboard: Dell Motherboard
- processor: AMD Phenom II 6-Core 1055T
- ram: 6GB
- Video Card: ATI Radeon HD5670
- sound_card: Soundblaster
- Hard_Drive_Capacity: 1TB
Hi Trevor,
I don't know if Mike Warren was implying maybe that after he had split the audio from his video clip, that he may have done some editing to that split audio clip. If not, it inspired a question in my mind - for whatever reason, if someone edited the split audio clip and wanted to reunite it back into the original video clip, can VS10 accommodate that? And would it override the original audio clip still embedded in the video clip. On the otherhand, would there be a good reason to reunite it back to the video clip?
Intermediate renders are such a cool thing to get around some of VS10's limitations. There are so many edit features that can be accomplished thru intermediate renders. It definitely fosters creativity.
Thanks, Trevor.
Thanks, Trevor.
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Sony DCR-TRV315 Camcorder
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
The underlying question was----Is splitting audio irreversable?
Well no its not , you can always revert back to the original video and audio file.
When you split audio Video Studio does two things.
1 / mutes the video track
2 / creates a copy of the audio in the voice track
You can revert these conditions, delete the voice track and undo the mute.
If you split audio and then edit the audio file, you can then render the project to a new file.
This will combine the new audio with the video as a single file.
I have had reasons to split audio, but few and far between.
As a normal editing process I cannot see the reason to use this option, but the questions regarding split audio still appear on the forum.
I just wonder why users are taking this option.
Trevor
Trevor
rvtraveller
I frequently use the split audio feature when I have a silent video to add, extra noisy audio track in a video or an inserted digital photo. I repeat an appropriate portion of the split audio track for continuity of the final result.
