tansition effect applying to images after inserted?
brucefl
motherboard: I7 3770
processor: 3-4 Gig
ram: 12gb
Video Card: NT Geoforce 640
Hard_Drive_Capacity: 2 T
Corel programs: VS21 VS18thru21 and more PIX13
Post by brucefl »
Is there a way to insert an effect into several slides after they have been added to the timeline?
rpavich123
Post by rpavich123 »
Bruce,
Yes, there is; just go to "clip" view, (I think it is) and drop a transition between the clips..
bob
brucefl
processor: 3-4 Gig
ram: 12gb
all at once?
Post by brucefl »
I should of been a little clearer, now that I read it.
Is it possible to insert the same effect into several
clips all at once, one you insert the images?
Bruce
rpavich123
Bruce,
Yes, when you "double click" a transition it will fill the next available slot between clips...
So highlight the spot to start at and keep a clickin'
bob
andrewt
Re: all at once?
Post by andrewt »
brucefl wrote:Hi,
Bruce
No
but as Bob said by doubling clicking a transition it will insert in the first available space.
If you have inserted a lot of images/video to the timeline without transitions, the easiest is to copy them to the library.
change File Preferences to Use default transitions
Delete the offending clips and drag them back from the library.
Otherwise get it right first time.
Trevor
