I am producing a sports highlight DVD for paying customers and am just about finished with this large project, but I keep running into this roadblock.
I have 20 separate mpegs with the following properties:
NTSC DVD
MPEG-2, Lower Field First
24 Bits, 720 x 480, 4:3
29.97 frames/sec
Variable bit rate (5500 kbps)
Dolby Digital Audio
2/0(L/R)
256 kbps
(FYI, I had to use that bit rate because the project is 1 hour and 38 minutes long, plus a ton of titles, effects, etc.) As most of you know, I follow the Recommended Procedures by creating my video files and then inserting them from the Share/Create Disc step. I then chose my text menu, customized it, and set the Project Settings to match my mpeg settings. I then proceeded to the Burner module where I chose to create a DVD folder instead of burning the actual DVD. It did its thing for several minutes then came back with the dreaded Convert Step… I searched the forum and found that many problems are due to incorrect settings so I went back and double and triple checked my settings and still got the message, after numerous attempts.
Since I was confident that the mpegs were not the problem I went back to the menu stage to eliminate some things in hopes of pinpointing the problem. The first thing I did was uncheck the Create Menu box. I went to the Burn module, chose DVD folders, and wouldn’t ya know, it worked! "Operation Successfully Completed". Ok, so now I’m getting somewhere. I went back and checked the Create Menu box, as I need the menu. I then chose one of the stock menus and made no changes to it. Went to the Burn module…Convert Step Got Some Friggin Problems.
So as it stands at the moment, the menus are causing my problem. (I would like to note that in the past month I have successfully created two DVDs, one with a menu (customized) and one without, and there have been no changes to my computer during the interim.) I couldn’t investigate any further, as I had to leave for my real job. But my HD is defragging at the moment and if that doesn’t cure it I will try a repair/reinstall. But beyond that, does anyone have any other ideas as to what might be causing this, or am I missing something that is painfully obvious (except to me)?
