Using DVD Authoring with MSP8 I can create menus OK with templates supplied. I know how to change background, music etc but all I want to do is create a very simple menu. This consists of a single image PAL 720x576), one piece of background music and perhaps a title that says... Press > to play overalyed on the image. Obviously, when the user hits the DVD > button, the main feature plays. Any suggestions on how to do this?
Thanks,
Simon
A very simple menu?
Terry Stetler
Thanks for the reply Terry
Just tried this on your recommendation... I just end up at the last page that allows you to burn the disk. I still can't see how to generate the simple menu described above. As I said, I have absolutely no problem generating a menu from the templates provided. Perhaps (as usual), I haven't described properly what I want to acheive.
The user puts the DVD in the player, the disc loads and presents an image on the screen with some background music - which loops until the user presses the Play button on the DVD player. The main movie will then play.
Simon
Simon
Create a your movie with a very brief (1 frame?) image clip right at the beginning. Switch off motion menu. Type your text onto the menu and drag the 'movie frame' over the text ( or move the text ).
Or you could add an image clip at the beginning of your dvd project. But I think it will create a slight pause in the play - not that anyone will notice as the movie will just be starting
