Can I save a WMV file at 640 x 480?
adamoforegon
The only options I find are 320x240. There are about 30 differnt versions but they all save at 320x240.
Right now I have to save an AVI file and then use a 3rd party PGM to convert it, but the AVI files are huge, 1 GB/minute.
ANy thoughts or am I doing something wrong?
THoff
Vicki
- processor: 2.80 gigahertz Intel Pentium D
- ram: 2 GB
- Hard_Drive_Capacity: 155GB FREE
- Monitor/Display Make & Model: DELL E177FP [Monitor] (17.1")
Can I save a WMV file at 640x480?
Hi, I was trying to do the same thing, ie save a WMV file at 640 x 480. When I go to share, share online, and select best quality, 640 x480 is listed there in the save dialog box properties, however the output is still only about 320. Also, when I go into create video file, custom, wmv, none of those choices allow me to create a 640 size file and on the profile tab, frame size is grayed out. I'm stuck and confused.
I tried making it into a Quicktime Movie too, but horrible results, it showed a white screen between each clip. The first try 4mb with the white screens and second try over 1 gb.... for a 1.5 minute video. Strange.
I'd appreciate any help someone could provide.
Thanks.
Thanks.
voidix
Hi Vicki, I had the same problem when I purchased ulead. Turns out I just didnt have the newest WMV codecs.
Here is my old post:
http://phpbb.ulead.com.tw/EN/viewtopic. ... highlight=
If this looks like your problem just go DL the windows media 9 encoder pack.
After that use the Make Movie manager to create a custom WMV template.
Vicki
- ram: 2 GB
WMV - 640 x480
Hi, thanks for responding...
I had downloaded and installed the codec pack last night, but still no change. I don't know how to get Ulead to recognize it. It still says Media Pack 8. Maybe I need a specific one?
I had a trial of Pinnacle last month when I was deciding between the programs and was able to export to WMV 640 with no problem, so maybe the problem lies in the installation of Ulead.
Do you have a link to the codec you used, or did something within VS to import it? Or do I have to reinstall VS?
Thanks....
Thanks....
Pentium D 2.8 GHz, 2 GB RAM (Dual core)
Radeon X300 SE
Radeon X300 SE
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
If this size is something you do regularly then you may want to use the make movie manager to create and save the attributes for your wmv. I have several set for size and bitrate for wmv so I can use the appropriate setting based on how I am delivering it.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
GuyL
- processor: I7 920
- ram: 6GB
Vicki
- ram: 2 GB
WMV - 640 x 480
Hi all-
Problem solved- doing happy dance.
Downloaded and installed Microsoft Media Encoder 9:
http://www.microsoft.com/downloads/deta ... laylang=en
Rebooted, held breath, opened up project and share tab>create video file>custom>wmv
All the missing profiles were there, including the Neptune Best (640)
Project was successfully created.
Did NOT have to deinstall/reinstall VS
Thank you all so much for your input and great advice!
Radeon X300 SE
Radeon X300 SE
