Hello,
I've tried to burn a dvd with Ulead Movie factory 5 Plus. I chose 1 file (AVI format, 600 Mo). Of course, it then gets bigger (8 Go) but I've selected GQ quality which says it needs 4 Go as space on the dvd. When I try to burn the dvd, MF5 says I may not have enough space on the disc but accepts to burn the dvd (is that okay ? I've checked the box that makes the menu not bigger than 30 Mb, so that I should get enougn space on the dvd !) Second thing is that 17 hours were necessary to burn 40% only ! I've stopped the burning state because it will obviously won't work.
Can someone tell me what can I do to make things work fine ?
Thanks for your help !
prob with runtime burning
Re: prob with runtime burning
Check the capacity bar at the bottom of the MF screen. If the bar is entirely green, you're ok. If it shows an orange portion on the right (and MF also warns you there may not be enough space), you should still be ok. If there's a red portion, take the warning seriously.zezette wrote:When I try to burn the dvd, MF5 says I may not have enough space on the disc but accepts to burn the dvd (is that okay ?
You need to tell us a bit more about your environment before anyone can offer useful advice. Please check PLEASE READ THIS FIRST BEFORE POSTING!!!zezette wrote:17 hours were necessary to burn 40% only ! I've stopped the burning state because it will obviously won't work. Can someone tell me what can I do to make things work fine ?
