Update - I rendered a previously captured MPEG2 (HDV) to DivX in HD using the recommended insane quality. I am typing this reply as it's rending. CPU utilization seems to be split between both cores now and overall 87%. It was 99% with both CPU's showing the same utilization at any point in time.
This is a good improvement in performance over the non-SP1 VS10+. Still more room for improvement IMHO.
Good luck all....
Kevin
"Ulead VideoStudio 10 Service Pack 1" Question ???
blplhp
- motherboard: Dell Motherboard
- processor: AMD Phenom II 6-Core 1055T
- ram: 6GB
- Video Card: ATI Radeon HD5670
- sound_card: Soundblaster
- Hard_Drive_Capacity: 1TB
How do you view the CPU usage of both cores of a dual core processor? I typically use the Windows Task Manager|Performance dialog box, but I only see one meter, although the meter does have two separate columns. But for me, the meter always reads the same in each column. And there is only one percentage read-out under the two columns. Is this the utility to use to check the dual core processor performance? Does each of the two columns represent each of the dual cores? If both cores are being utilized by the base VS10+, should the meter show different levels in each column or the same? Or is there a different utiliy to use to gauge CPU usage of a dual core processor? I have a project to render tonight, and I want to gauge the CPU usage to see if my dual core processor is being utilized to its potential by the base model of VS10+.
Thanks.
Thanks.
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Sony DCR-TRV315 Camcorder
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
blplhp
- ram: 6GB
Ok,
I rendered a 21 minute project of captured and edited DV_AVI video files, with added titles, split screen effect, added audio background music, bmp photos, etc to a mpeg2 video file. The render took 29 minutes on my Dell XPS400 with the 2.8 GHz Pentium D 820 dual core processor. I ran Windows Task Manager|Performance tab during the render. I saw that the CPU Usage History graph is broken up into two windows, which suggests to me that this is looking at each core of the dual core processor. The left graph averaged its waveline on the 60% line, +/- throughout most of the render. The right graph averaged its waveline on the 80% line, +/-, throughout most of the render. In some parts of the render, the right graph flatlined for several moments at 100%, while the left graph rose to 85% - 90%. The CPU Usage meter averaged 60%-70%, and peaked at 100% several times. Does this say anything about how my base model VS10+ is using my dual core processor? What is the possibility that the new service pack for VS10+ will increase my performance with VS10+?
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
