Problem with videostudio->How to join clips?
pviran3
Hello
I captured 3h of video and made 30 clips.
Now i want to use crop and color filter, but I don't know how to use it on all clips at the same time.
I can only edit only one clip at time.
I want to join all clips in one and then, use a filter, but I don't know how to join back all clips in one.
Please help.
Please help.
Javadog
Hello all, I have been reading through the posts for a while and have learned a lot. Thanks for that.
One trick I learned a while back and have used successfully might help here. Rather than create a new video file first, just add all the clips to the time line, then save the project.
Open a new project and add the one you just saved (open as a video file). Then apply whatever filters you want and create the video file after your finished.
Learn something new every day!
Jeff
Dentler's Dog Training, LLC
Hi Terry
I agree with you.
I have just tried VS 9 and i can drag and drop a VSP to the timeline. Resulting in one clip.
I have only seen this whilst messing about, but it is interesting that it’s a possibility, if the resultant video file is ok quality wise, then it may be a very interesting option.
Others on the forum have mentioned this approach when creating slide shows.
Needs looking into!
Trevor
I agree with you.
Needs looking into!
Trevor
I just clicked on Insert Media Files Into The Timeline and chose Insert Video and it put it right in there.but how do you add a project as a video file - if you haven't created a video file. trying to import a .vsp file as a video gets you a "File Mismatch" error.
What problems might there be?I'd question the stability of the resulting file doing it this way.
Jeff
Although by importing a VSP into the timeline you can treat it like a video file, it isn't a video file. It's a VSP file in it's component parts. You may be able to get away with treating like a video file, depending on the criteria you're applying to it, but I'd rather render my project twice with no quality loss than go this route. just a personal opinion.
Terry
