Error message about chapter entry numbers exceeding frames
hagadorn
I have successfully burned many DVDs using VS10 but today I got the following message and my burn process was halted: "Some chapter entry frame numbers exceed the total frames". Does anyone know what it means?
Usually it means that you edited your video after you had set chapter points - thus the number of frames between set chapter points is not the same as it was when you set the points. Try re-creating chapter points from scratch.
If you didn't edit your video after you set chapter points - I don't know what it means.
