Thanks for your suggestion. I opened VS9 and dragged a single clip to the timeline. Any of my clips I see Project =PAL and Clip =PAL. If however I take a clip from the as supplied library e.g. testcard or 54321 I get Project =PAL and Clip = (apparently NTSC although it does not say so)trevor andrew wrote:
Insert any clip to the timeline Share Create Video File—What do you see in the list NTSC or PAL ?
Edited DV not as good as original
Doverwhite
Doverwhite
Doverwhite
I have read the suggested material and am managing properties at all stagesjchunter wrote:Dover,
I am sure that the reason you are getting degraded quality is that you are not explicitly setting up the properties when you create your video file of the project: (SHARE/CREATE VIDEO ). You are accepting the default properties, which do not match your captured video file properties.
I have also tried experiments with short projects with different properties but usually end up with a same or worse result. I do not accept the defaults and as far as I can see the project properties are the same as my imported video properties.
Doverwhite
As I do not understand the instructions given for posting jpeg screen dumps on this forum I cannot post clip properties. But I can assure you that all my clips imported to the timeline and edited have IDENTICAL properties to the project at least as displayed by "properties" in the S/WSounds like your project and clip properties are not jiving. You've never posted both of them. Would be interesting to see.
I think I should have explained a little better.
When you installed VS you have to choose the TV system, either Ntsc or Pal
You are in England and use Pal.
In one of your earlier posts you indicated Ntsc, to clear this point, I asked you to look at the Share-Create Video File option. (Insert any clip to the timeline Share Create Video File—What do you see in the list NTSC or PAL ? )
This shows a list of available templates. If you have installed to Pal all the templates will indicate this.
Project properties
Video studio can change project properties to match the video clip properties.
Go to File Preferences-tick Show messages when inserting first video………..
When inserting the first clip into a new project a pop up window prompts you to change the properties Press details to view the properties then select yes.
Your quality problem is after creating a new video file, correct.
We have seen the properties of the original video.
What are the properties of the poor quality video?
Read My Quick Guide to Dv-Avi from the link below
Trevor
Project properties
Trevor
Doverwhite
Hi Trevor many thanks once again for your reply, hope your help leads me to a solution of the problem.trevor andrew wrote:Hi
Yes they are all PAL except WMV phone format options. My mention of NTSC was because I found that if I insert clips from the ULead supplied library into the middle of my project e.g. the testcard then the clip properties are NTSC. Furthermore I have observed that in the video file created from this test project whilst my footage shows a degradation in quality the test card does not.
OK Ill try this and report back but what is difference to setting properties as first clip?trevor andrew wrote: Project properties
Quality of original clips is excellent but quality of new video file is not as good.trevor andrew wrote:
Trevor
Properties of poor quality file as follows:-
PAL (25 fps)
Microsoft AVI files
24 Bits, 720 x 576, 4:3, 25 fps
Lower Field First
DV Video Encoder -- type 1
DV Audio -- PAL, 32.000 kHz, 12 Bit, Stereo
Many thanks for help will read your guide.
Jerry Jones
I had a look at your clip properties:
PAL (25 fps)
Microsoft AVI files
Lower Field First
Did you know your camcorder might be able to record audio at a higher quality setting?
I always recommend that camcorder users adjust their camcorders -- if possible -- to record in 48.000kHz, 16 Bit.
Your audio will sound better because 16 bits are far better than 12 bits.
I wish the manufacturers of DV camcorders would STOP using 32.000 kHz, 12 bit as their default setting.
It really screws up a lot of beginners.
Now, back to your problems, you must make sure that your PROJECT SETTINGS in Ulead VideoStudio are adjusted to MATCH your source video/audio properties.
If you do that, then Smart Render will be allowed to function properly and your clip quality will not degrade when you edit.
Jerry Jones
http://www.jonesgroup.net
PAL (25 fps)
Microsoft AVI files
Lower Field First
Jerry Jones
Gateway 7426gx
http://tinyurl.com/hagye
Doverwhite
Jerry Jones
Thanks for your comments re sound but I have feeling without looking that my DV camcorder which is an early one only has the one option - but willl checK. Surprisingly sound quality from a camcorder is not a particular issue with me but getting the best video quality results is.
As far as I am aware my Project settings ARE Identical to my source video/audio properties but I am still getting a degradation in picture quality post editing. The only thing I have not had a chance to try yet is the suggestion of Trevor Andrew above of doing this via the first clip pop up message but will try tomorrow and report back.
Jerry Jones
Well, I've been using Ulead software for years.Doverwhite wrote:As far as I am aware my Project settings ARE Identical to my source video/audio properties but I am still getting a degradation in picture quality post editing. The only thing I have not had a chance to try yet is the suggestion of Trevor Andrew above of doing this via the first clip pop up message but will try tomorrow and report back.
I've never encountered a situation where the Smart Render doesn't work.
Smart Render is activated when the software user precisely matches project settings to the properties of the primary source media, i.e. DV .avi files.
Make sure that -- in your PREFERENCES menu -- you've selected BEST as your "image resampling option."
Jerry Jones
Gateway 7426gx
Hi Doverwhite
I have read the posts again and provided the Project Properties are matching the Video File (and I believe they are ) I cannot see anything you are doing wrong.
Two things I would try:-
1 / Disable Smart Render whilst creating the Dv-Avi (some users have reported problems when using this option)
2 / I would suggest that you render your project to Pal-Dvd, the standard template is suitable for up to 60 minutes of video.
If the quality is ok, as it should be, then it may be a Avi codec problem (this is getting a little over my head)
Trevor
Trevor
Doverwhite
Hi Trevor and all other posters who have tried to help. Many thanks but...trevor andrew wrote:Hi Doverwhite
Trevor
I tried your two options above but to no avail. I have tried various other permutations/ options* for several hours on various 3-5 minute projects. But always compared with the imported footage the resultant .avi is not as good. I was beginning to think I was going nuts and got monitor blindness so I got my wife who is an accomplished water colour artist to do a "blind"! ?? test of the comparisons and without prompting her first reaction was that she picked out the original as best and said the edited copies in comparison looked fuzzy and the colours were washed out . We then experimented with the hue, saturation, brightness and contrast settings on the player in the hope that at least the colour rendition could be improved but to no avail.
I have also found that if one saves a project whose properties are apparently OK and then close VS9 and then re-open - share - open project- create video file - PAL DV then the properties shown are avi type 2 (type 1 original ) and PCM audio! Interestingly if you then save this gives the best quality picture of all the edited copies but it still isnt as good as the original.......??????????????
I have also found that if one builds a project from the clips in the ULead provided library and then saves this as a video file then even though these clips are NTSC format and I am producing a PAL avi they reproduce perfectly even to my dear wifes opinion. This was as my earlier experience of using the test card clip.
I am convinced that this s/w was written around a NTSC profile and has compromise problems when editing captured PAL footage. Yes I am perhaps more critical of picture problems than most and I am sure that in NTSC land everything is OK but I am surprised that other users in PAL land have not perceived the same problem as I see.
I regret that I am about to give up on this s/w. This is a pity as I like its general approach although it has some quirks. I never got the disc burner to work and always used an external burner. I went to direct .avi capture as I found that editing captured DVD was hopeless. I am told I need Womble for mpeg and Vegas for avi unless anyone can convince me trialling VS10+ will do any better!
* Permuted combinations of same as project/same as first clip/ PALDV/ Custom/smart render on/off/ nonsquare pixel rendering on/off etc.etc.
Hi Doverwhite
I have no problems with quality when working with Dv-avi using the same approach as you.
Although the s/w is based on Ntsc I do not think this has anything to do with your poor quality.
When you capture via firewire to DV, you are transferring the video from your camera to the PC. No additional re-coding takes place. What you have is what you get. (Dv-Avi.)
During capture/transfer there should be no Dropped Frames especially when using Dv-Avi. (Can you check this point—the drop frame counter is lower right in the info panel)
Editing should be no problem.
Then Share---Create Video File----Same as First Clip should produce the same quality video.
Here you are seeing a marked reduction in quality.
At this point I would be considering a clean install of Video Studio.
I am thinking a codec problem, of which I know little about.
Can others on the forum with knowledge of codecs comment please.
All the Best
Trevor
All the Best
Trevor
Doverwhite
Many thanks once again Trevor.trevor andrew wrote:Hi Doverwhite
All the Best
Trevor
As I have said before I am not sure where codecs come into this as we are not (hopefully) recompressing this video. However I notice that the supplied library clips use a different codec. Also like you I find this area a bit beyond my current understanding.
With regards to dropped frames I cannot see any reference to them - do you mean in the information panel shown during capture under the scene counter? Does it only show if there is a dropped frame?
I have also thought of trying a full de-installation/re-installation. I have often seen references to update patches on this forum particularly in connection with burner problems but I can never seem to find any patches that are relevant either to burner or other likely problems such as this - am I looking in the wrong place?
Drop frame counter should be lower right in the information panel.
During capture you can also see the Scene Numbers.
VS 9 updates from here
http://www.ulead.com/tech/vs/vs.htm
for burner look at General Updates
The burner update should not be your problem, you have not got that far yet, but you will.
Trevor
Trevor
Doverwhite
Hi Tevor again many thanks for your continued interest.trevor andrew wrote:Hi
Trevor
I see no dropped frame counter, lowest right on info panel is scene counter.
Wrt burner updates - yes I have already been there as part of my even more disappointing experience with editing from Mpeg capture. Basically the burner in my package does not work it either falls over or produces DVD's that wont play properly (jerky motion or freezes and halts). I resorted to saving to VOB at highest possible bit rates and then either burning these if less than 4.7 GB using Roxio or (better) DVDencrypter or shrinking using DVDShrink or (better) DVD Rebuilder. Note : all apart from Roxio is freeware.
Will try your link and report back!
