MediaStudio Pro 6.5/Video Editor 6.5 Image Size issue again
Bronson
Post by Bronson »
Hello,
Thank you for this site as I have been trying to figure out this issue for 48 hrs.
I am complete newbie to this software and just looking for some help with an issue. I have a 4 min 55 mb mpg that I created with images, text, and sound (one mp3 song); no video at all in it. It looks great, runs fine (from my tests) but the audio skips through out the playing of the actually mpg.
I have tested the audio out within the program and on Winamp and it does not skip. I have used different mp3 songs, and tried a wav file and it still skipped....
Can someone help me please?
Thank you in advance
Dara
Windows XP OS VE
Bronson
Post by Bronson »
Update and correction: It does NOT skip on a different mp3 song. But still skips on the original song that I need to use for the clip....
Devil
Post by Devil »
If you do a search here for mp3, you will find you are not alone.
The problem is that there is no real spec for mp3 audio as a stand-alone audio format. It is part of the audio in Layer 3 of MPEG files and should not really be separated. The problem is that the compression algorithm is quite good, with relatively little loss of quality but the way different softwares wrap it up for stand-alone audio changes from one to another. They may all play more or less correctly in an MP3 player but, because they do not conform to the full MPEG spec, they may or may not be used correctly in a video application, resulting in loss of synch, no audio or poor quality.
Conclusion: NEVER use MP3 in a video application. OTOH, if you convert the MP3 to WAV before you bring it into the timeline, it will probably work fine.
heinz-oz
Post by heinz-oz »
Another thing may be the support for mp3 sound in MSP 6.5. I know from different posts here that some people are using mp3 files successfully in later versions of MSP. I never used mp3 and, hence, cannot comment on it's suitability for MSP7.
Bronson
Image size
Post by Bronson »
Thank you Devil and Heinz-Oz. I did read that mp3 format does not do well so I tried a couple of other songs until I got one to work....:)
I do not know if I have to post another thread but does anyone know if there is a way in the program/project to keep the original size of images intact vs getting blown up to the size of the frame size?
Thank you
Devil
Post by Devil »
This has also been answered many times. You apply a Moving Path 2D Basic, check the keep aspect ratio box and adjust the size and position to suit. This is even easier in MSP8, as you can drag the corner/position in the Preview window, thus avoiding having to enter figures.
Bronson
Post by Bronson »
Thank you again. I tried this and the images shakes in movement?
I did as you said and manually put in the image's original size.
Sorry to be a pest. :oops:
Bronson
Update
Post by Bronson »
Update: Devil I did a search and still unable to figure out how to stop the image from moving. Plus the "ok" button is greyed out when I select "keep aspect ratio" even if the desired effect was what I wanted.
Help please.
Devil
Post by Devil »
You must have identical figures at both keyframes on either end of the time scale to keep it stationary. I don't understand why the OK button is greyed out.
Bronson
Post by Bronson »
Thank you Devil. I am sorry to be such a newbie but I am really having problems understanding how to keep the image intact and the actual size of the image.
Do you mean the Width has to match the X and the Height has to match the Y? [/img]
Devil
Post by Devil »
This may differ in detail to what you have, but it should be similar.
Bronson
Post by Bronson »
Devil I had just figured it out when I saw your screen shot...thank you!
You won't believe it but the "ok" button is still greyed out....yikes.
I didn't know how to paste in a screen shot so I put it online:
http://ftp.datx.com/Public/Misc/MovingPath.doc
Devil
Post by Devil »
I take it your image is more than 1 frame long????
Bronson
Post by Bronson »
Yes, they range in duration of 5-10 seconds. They are all jpg's.
Bronson
Post by Bronson »
Now I am obsessing over this but determined to figure out what I am doing wrong. I created new projects and tried to use the moving path features and no luck. Also tried different formats of image files. It does not only happen in the 2D Basic options but all options in the production (filters and effects). I have a full licensed copy of Video Editor so that can't be it. What the heck am I doing wrong....
Thank you in advance.
