Group objects
jl
Group objects
When grouping objects you get a choice of which object's pivot to use. There is a box allowing never to ask again which pivot to use and I have wrongfully clicked it. Now when I group objects I do not get a choice of pivot. Is there an easier way to get this back to normal without re-installing the studio?
Search your system for the u3edit4.INI file. For XP systems it should be located on your system drive in the 'documents and settings\<your user name>\Application Data\Ulead Systems\Ulead Cool3D Studio\1.0" directory.
Make a backup copy of the file just in case and then find the SetGrpPivot= entry and remove it.
That should do it.
Hope that helps.
- Ken
That should do it.
Hope that helps.
- Ken
I just done a quick test, and this worked.
Instead of deleting or removing that entry just set it to 1. So that line would read SetGrpPivot=1. When you check the box to not show that message again, it changes that setting to 0.
When I changed the setting back to 1, the group pivot message was back..
