no audio with firewire
aqctv
Post by aqctv »
When I try to capture using firewire in VS 10 plus in the capture window the video is spilt into 4 pictures with a large green line down the middle. when I play back the captured file video is fine but there's no audio.Tried two different camera's same result
DVDDoug
Moderator
Post by DVDDoug »
Are these both DV cameras? (Do they use Mini-DV tapes?) The audio and video are multiplexed together on the DV tape, and they stream into the computer together via the Firewire connection. If you then "capture" to an AVI/DV file, the DV data should be unaltered.
If that is your set-up, it is more likely that you have a playback problem, than a capture problem.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
aqctv
Post by aqctv »
Yes these are both mini DV camera's Canon ZR 20 and Sony VX 2100 when I capture the same clip in using the AV out of the camera's it's fine possible bad firewire cable maybe?
GeorgeW
Post by GeorgeW »
When you use the firewire connection, what format are the resulting files you capture to your hard drive :?: Can you list their properties?
Also, what are you using to play them back on your computer :?:
George
aqctv
Figured it out
Post by aqctv »
The clip had LPCM audio changed the capture format option from DVD to MPEG and now the audio works Whats LPCM audio?
