Bulk Changes To Images and Transitions In VS10
broo0591
Is there a way to make bulk changes to images (image timing, transitions, etc) in Video Studio 10 or do I have to make changes to individual images one at a time? In some instances, it is very convenient to change image timing, transition timing or even transition type to several images at once, but I have not been able to do this.
blplhp
- motherboard: Dell Motherboard
- processor: AMD Phenom II 6-Core 1055T
- ram: 6GB
- Video Card: ATI Radeon HD5670
- sound_card: Soundblaster
- Hard_Drive_Capacity: 1TB
For image timing (duration) and for transition timing (duration), you can set default values for these, and then just the edit the few in your timeline that need to be different. Do this by going to File|Preferences|Edit and use the provided boxes to set your duration times. For setting up a default transition type, go to File|Preferences|General and select your transition type in the box called "Default Transition Effect". Be sure to place a check mark in the check box just above this menu option called "Use Default Transition Effect".
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Sony DCR-TRV315 Camcorder
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
broo0591
There is one option to change the duration of all the image/color clips. With all the clips highlighted that you want to change, go to Clip menu, Change Image/Color Clip Duration. Everything else has to be done manually..
blplhp
- ram: 6GB
Ron,
How do you multi-select image/color clips to apply the "Clip menu, Change Image/Color Clip Duration" file command? When I'm in the Storyboard view, I hold the Ctrl key down while clicking on several image/color clips, and more than one clip won't stay highlighted. Then the Change Image/Color Clip duration in the Clip Menu is grayed out. How do you do this?
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
blplhp
- ram: 6GB
Ron,
I held down the Shift key and clicked on two consecutive color clips. The two color clips show the blue highlight, but when I click on Clip in the menu bar, "Change Image/Color Duration" is still grayed out.
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
blplhp
- ram: 6GB
Yes, I'm doing this with color and image clips only, but it doesn't work for me when I highlight two consecutive image or color clips. The Change Image/Color Duration in the Clips Menu Bar remains grayed out.
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
