Can I initialize/set file names? (other than .dwz file)
ae-piper
When I use MF3 to transfer, using IEEE1394/firewire, camcorder video and create DVDs, the file names are something like dmf041214-002.xxx (extension is .mpg, .upd, .dwz). I can figure out that the file name is comprised of 'dmf' (DVD Movie Factory), date (yymmdd), a dash and a sequence number. I can do a "save as" to "rename" the .dwz file, but I don't see any option (in MF3) to change the name of the video (I'm using .mpg) and/or .upd files. I have renamed those files outside of MF3, but then have to "relink" the files when I open the MF project. But I'd ideally like to do so within MF3. Does anybody know if/how I can name those files within MF3? Thanks!
htchien
I think you can only do it in manually and let DMF to relink them.
You can fill the Ulead Tech Support Form to ask Ulead to add the feature.
Hope this helps.
H.T.
Hope this helps.
H.T.
