I had the (apparently quite common) problem that PI would fail to start, stalling when loading U32Ico.fio.
I pored over many threads and found little joy. Deleting temp files and clearing temp folders didn't do a thing.
One user aired a suspicion that the problem may be related to having PI installed on a drive other than C:.
Through my own error, my PC had (for a couple of weeks after a major upgrade) no C: at all. Long story, don't ask. Bottom line, WinXP was installed on E:, and so were the apps. This caused a few annoyances at install times when things would try to install to C: (or at least to unpack files into temp directories on C:), but I mostly managed to work with it.
In the end, as a last resort, I thought I would bite the bullet and re-install the whole shebang on C: - a clean Windows install with fresh installs of all the apps.
Lo and behold, PI installed just fine and now works as designed. I used exactly the same install files, followed exactly the same process.
Sorry, I can't explain WHY this has worked for me. Maybe there's something hardcoded to C: deep within the bowels of PI, and maybe this caused my problem. Maybe it's just coincidence. But I thought that I should at least report that...
... IF you have problems with PI stalling when trying to load U32Ico.fio at startup, and...
... IF you have PI installed on other than C: (you may or may not even have a C:)...
... THEN re-installing PI on C: (and/or rebuilding your system so that you actually have a C:) MAY solve your problem.
It seems to have worked for me.
Richard.
Stalling at startup when loading U32Ico.fio - fixed (for me)
richardnau
Video editing PC:
C2D E6600 CPU on Asus motherboard
2GB dual channel DDR2 RAM
7600GT PCIe video card
320GB RAID 1 SATA system drive
400GB RAID 1 SATA documents drive
400GB video drive
Samsung and Pioneer DVD burners
Vista Home Premium 32 bit
400GB video drive
heinz-oz
richardnau
Like I said, maybe it's just a coincidence. Someone speculated in this direction in an earlier thread, and I'm just reporting what I found.
Best,
Richard.
Best,
Richard.
Video editing PC:
400GB video drive
400GB video drive
- ram: 2 GB
- sound_card: Intel GMA 950
Was it this post or another?
http://phpbb.ulead.com.tw/EN/viewtopic. ... 4789#84789
richardnau
Steve,
No - not your post.
There are a couple of hints at the bottom of this thread:
http://phpbb.ulead.com.tw/EN/viewtopic. ... u32ico+fio
But I'm sure it was something else that sent me in this (last ditch) direction. It might have been this one:
To be honest, I went down so many blind alleys, I'm not certain which post gave me the biggest hint. And, as I said in response to Heinz above, I can't be CERTAIN that re-installing to C: was the fix. Could be coincidence - many things change with a fresh Windows install...
Richard.
No - not your post.
Richard.
Video editing PC:
400GB video drive
400GB video drive
