How to actually use "FXBench"???
Post by Trevor Andrew »
Hi Daniel
Maybe you installed FX Bench to your D drive.
You have the option to select an install folder during the installation procedure, normal default C drive.
And if this is where VS is installed then FX Bench should be recognised.
Trevor
daniel
Post by daniel »
Maybe... Would make me feel better.
Since I always install Everything on the D: I routinely edit the proposed paths and just alter the letter C to D, keeping all the rest as is. So this action does not really register in my memory, and I don't write it on my to-do-for-reinstall check list.
