How to actually use "FXBench"???
rpavich123
I've download burgers transitions and FXBench. I know what the transitions do....for the life of me I can't figure out how to actually use FXBench....what do I do?
I open the program and just stare at it...
I've search this site, I've went and read what I could about it but I'm still mystified
bob
bob
rpavich123
Hi Bob
FXBench is a Video Filter, just the same as the video filters used within Video studio. (except it has mutiple choices)
This text was taken from the help files (F1) (video filter)
To apply a video filter to a clip (video or image) in the Video Track:
1. Select a clip in the Timeline.
2. Click the Filter tab in the Options Panel.
3. Choose a video filter from the Video Filter folder in the Library to apply to your clip (by clicking the thumbnail).
4. Drag and drop the video filter onto your clip in the Video Track.
Hope this helps
Trevor
Hope this helps
Trevor
rpavich123
rpavich123
NoM.O
Quite possibly. Do you have VS installed in the default directory on C: or somewhere else?rpavich123 wrote: Idon't see it...I uninstalled FXBench and reinstalled it and when it was done it said "no Ulead products found" and "no adobe products found"...
Could that be what's wrong?
According to this thread - http://phpbb.ulead.com.tw/EN/viewtopic. ... all++bench - FXBench is hard-coded to only look for VideoStudio in the C:\Program Files directory.
If your installation path of VS is totally different (maybe even on a different drive) you have to copy the Fxbench.vft file manually from your Fxbench installation folder to the vft_plug folder of your VS installation.
peace.
rpavich123
Stefan_Burger
Stefan_Burger
It will work, but only if you copy the fxbench.vft file from the installation folder of the fxbench-setup manually to the vft_plug folder of the installation folder of your VideoStudio or MediaStudio Pro setup.daniel wrote:I use D:\Program Files\ as home disk for programs and it's working; ???
As already mentioned: the installer of fxbench tries to locate your VideoStudio or MediaStudio Pro installation and (if found) copies for you the fxbench.vft file to those locations. In case of a different drive, this process currently fails und you have to do it manually.
Kind regards
Stefan
