Hi!
I just started to use Ulead studio with my Sony DCR-HC42E PAL camera. I successfully acquired all the scenes from two tapes, made two projects, created titles, etc.
However, when I started to create a DVD file from those two projects (made a menu, etc.) it happened that a total size to be written to a DVD is more tha 8 gig although two episodes are only 2.5 hours long.
Can anyone, please, advide on what I did wrong and how can I made the total size smaller so it fits onto one DVD (4.7 gig)?
Thanks in advance,
Sergei
A 2.5 hour DVD project is too large
Your video file has probably used 8000 kbps bit rate.
This is the standard VS template and will fit one hour to a disc.
You need to reduce the Bitrate in order to reduce the file size below 4.3 Gb/4.7Gb
A 3500kbps rate may do the trick.
Use Digital Dolby for the audio
2.5 hours is long to fit to a single layer disc.
There are Bit Rate calculators that can help in choosing a rate
http://dvd-hq.info/Calculator.html
Use the Tools Make Movie Manager to create a template.
Use Share-Create Video File to make a new file from your project.
Read ‘Bit Rates and File Sizes’ from the link below.
Trevor
Trevor
Use a lower bitrate. (Dolby audio will help reduce the filesize too, if you aren't using Dolby already.)
Here's a Bitrate Calculator.
2.5 hours is getting a bit long for a single-sided DVD. If you reduce the bitrate that much, you will probably notice the lower video quality. My "rule of thumb" is 90 minutes per DVD with Dolby audio. When I've pushed it past 2 hours, I've really noticed loss of quality.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
vomus
Hmm. Then how comes that a, say, 157 min Harry Potter movie fits on DVD with 5.1 audio?
Sergei
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
Hi segei,
Commercial DVD's have two main advantages.
First, they are "pressed" not burned so they can pack the data in more efficiently and accurately and this alone allows them to put more on the DVD than us at home using burners.
Secondly, they run a bitrate, I think, of about 4000kbs. If you and I did that the video would look not very good at all. The reason they can do that is that the MPEG encoders they use commercially scan the file maybe around 20 times before the software even starts to encode so that they are very, very efficient. The most you and I get is two-passes before encoding.
heinz-oz
THoff
phil.a
