OS - WinXP Service Pack 2
VideoStudio 10+
Camcorder - Sony DCR-PC105
P4 - 3GHz
HDD - 150GB & 150GB
RAM - 512MB
Video - NVIDIA GeForce MX 440
I connect thru a firewire, windows recongizes it as 'Sony DV Camcorder', & is also listed in my Device Manager Under Imaging Devices as 'Sony DV Camcorder.
My OHCI Compliant IEEE 1394 host controller MS driver version 5.1.2535.0
IN VS
Source - Microsoft DV Camera & VCR (Mine is not listed)
Device Control Manger - None (cannot change to MS 1394: unable to open...check if your device is ready)
Capture Plugin - Ulead Directshow Capture Plugin
The card works well with my IPOD & the firewall cable I just bought from the Sony store to use with my Camcorder & VS.
I did follow the procedure of Boot ->Camcorder ->VS
I did the re-register of the Microsoft DV codec.
I just can't get this thing to go, does anyone know why?
Ulead Does Not Recognize Camcorder - I read past posts
jchunter
Rich,
You have done your homework and everything should be good to go.
The only thing that I can think of are the Sony camcorder menu settings that enable DV capture.... Or possibly a bad firewire connector in the camera. It is generally recommended to plug and unplug with power off.
Anybody else have any ideas?
Jerry Jones
Re: Ulead Does Not Recognize Camcorder - I read past posts
I'd suggest that you try resetting the Ulead Direct Show Capture Plug-in.
You can do that by switching to the Ulead plug-in that allows for capture directly to the MPEG format.
Then switch back to the Direct Show Capture Plug-in for DV .avi capture.
Jerry Jones
http://www.jonesgroup.net
Jerry Jones
Rich7 wrote:OS - WinXP Service Pack 2
VideoStudio 10+
P4 - 3GHz
HDD - 150GB & 150GB
RAM - 512MB
IN VS
Gateway 7426gx
http://tinyurl.com/hagye
