Video is wide screen and I can't figure out why
rpavich123
Post by rpavich123 »
I just captured my 3rd video clips from my DV cam and this time they came in wide screen??!!
I didn't do anyting different; I followed the "capture" directions given on this site except this is the first time I captured to AVI instead of MPEG....
any quick ideas?
bob
heinz-oz
Post by heinz-oz »
Plenty, which one do you want to hear first?
Now, relax, get yourself a coffee or tea or whatever else tickles your fancy, forget about the fact that it is you who has this problem and read your post again :wink: Not much to go on, is there.
Have a read of this and come back with the proper information http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
rpavich123
Heinz,
I was just asking like that because I was at work without access to my PC with the video on it and I thought there might be a "just click this checkbox" kind of answer before I completely dove into it...having said that...yes, there was that kind of answer; I used the search function as your link suggested
QUOTE:
baroblik ...
I am using VS10. If you go to File > Project Properties
... it says Project template properties ... Edit file format:
On the drop down menu, it has options to select MPEG files or AVI files...
I notice when I select AVI files - my preview screen shows the black reveal bars.
When I select MPEG files, the black bars are gone.
END QUOTE
bob
Post by Trevor Andrew »
How are you connecting your camera.
Firewire, composite, etc
Select DV as the Capture Format, does it remain as DV or revert to Avi.
Any other option other than DV requires you to set the capture properties and the aspect ratio(normal default 4:3)
If DV then the capture process is copying/transferring the footage.
This is the best method, what you have is what you get.
The only ‘option’ being DV-Type 1.
If any other format.
Select the Options Cogwheel to access the Video Capture Properties.
Here you can modify the settings.
The project properties are usually changed by VS to match the first video clip inserted to the timeline.
If your capture was DV 16:9 then the project would most likely change to the same.
Right click a clip in the timeline to see the clip properties.
These reflect the capture settings.
Trevor
rpavich123
Trevor,
Thanks, I captured in AVI format...this was the first time I've done that...
I'm connecting thru firewire
It seems like the bars are there only on the PC....not on the finished rendered file....
bob
rpavich123 wrote:Trevor,
bob
You say captured Avi
Just to clarify
Was the Capture Format DV. :?:
If so then the capture should be ok.
Right click a file/clip in the timeline and select properties.
Read a look at widescreen 16:9
from the link below
Trevor
rpavich123
Trevor,
Thanks very much for the great link to your site...I gotta go home and start from the beginning and see what I've got...
I'll get back withyou....
bob
