Saving my Videos
piaso
Saving my Videos
Post by piaso »
I have VS8 loaded on my computer on my C drive. What I would like to do is download all my video onto an external drive or at least save it there and be able to work with it from there to save space on my internal drive. Help on this would be appreciated.
Rich2Putt
operating_system: Mac
processor: 2.9
ram: 8gb
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: IMac AIO
Post by Rich2Putt »
In VS8 "Capture" menu, change your capture setting from c:\ to your external drive letter. That should do it.
piaso
Post by piaso »
I tried but when you retrive it is says you can't
Rich2Putt
processor: 2.9
ram: 8gb
Post by Rich2Putt »
Piaso,
I recently installed a "second" HD to my pc. I also wanted to capture the video to my f drive. I changed the setting in VS8 where the capture menu is and it worked.
Are you using the correct drive letter? (D, E, F ???) and the right path?
If you are then I'm lost as to why it's not working for you. :(
joosuna
System_Drive: F
processor: intel dual core 3 Ghz
ram: 12Gb
Video Card: nvidia
Hard_Drive_Capacity: 2000
capture video to another hard drive
Post by joosuna »
When you click on the Capture Tab, look down below it, see the
faded "Capture Folder window? next to it is a icon of a folder. Click on the icon folder.
The will activate the window and give you the option of where you want the video to go to.
I usually finish my videos and go to the Share Tab and then create a Video Project and store my finished Video Project in my external back up hard drive.
62cwil
Post by 62cwil »
I use an external drive. When I set it up everything new capture, video files, projects, etc go to it and I can read it. Everything I previously did is unable to be read now as it looks for the external drive. I went in via explorer and moved all of my old files to the external drive and all works fine now. Hope this is what you are talking about and this helps.
piaso
Post by piaso »
Thank you all for your input. I have just been having such a time with this. First off my Cam takes mini DVD's and I have to download them from the edit function. Then because I am trying to download several DVD's and pick and choose excert from different ones I thought if I kept the orginal ones on my external drive and just captured the scenes I wanted I could bring them into the editor and work them and then save the finished product on my external drives as well and make DVD's. Am I trying to do too much to quick with very limited knowledge?
kebrinton
Post by kebrinton »
Piaso --
I assume you are taking the miniDVD out of the camcorder and putting it into the DVD tray of your computer, and going from there. Far simpler.
I believe the way to tell the program where files are supposed to go is to go to File > Preferences and make changes in the General and the Preview tabs. Under the General tab, set the "Working folder" to the place on your external HD. Same with Preview.
I assume you are using a USB-connected hard drive. I recently tried to install a Home Network harddrive and found that VS8 did not recognize it as a 'local' drive.
piaso
Post by piaso »
Your dead on the money.. I purchased a new computer that has a plug in hard drive. It fits in a slot in the computer but I also have an external that I had purchased earlier and it does operate on a USB port. I wanted to use that one first. I am going o try you suggestion and see what happens. I have to admit I never realized this stuff was this complicated. Thanks
