VideoStudio is slow when encoding video to a DVD
smelanson
When I try to encode video from an .avi file it takes over 16 hours to encode. The codecs for the file are Xvid and AC3, is there any reason why it would take this long. The same file in Sonic DVDit Pro or Nero Vision takes less then an hour, I have tried other files and its the same. I have tried disabling Hyper-threading but no change.
Your question needs some clarification. Are you encoding an AVI file (which is the carrier format for what in reality is an XVid file) to some other format e.g. mpeg-2? Or are you trying to encode from some other format e.g. DV/AVI or uncompressed AVI to XVid?
Whichever the case, it should not be taking that long to encode. Mind you, XVid/DivX seem to cause a lot of grief to Ulead users. I am assuming that you have a working XVid codec on your computer and have chosen it in the customise drop-downs as the decoding or encoding codec...?
smelanson
Terry Stetler
This is a common problem, and the cause is XVid.
Like many other highly compressed formats (WMV, DivX etc.) XVid's structure makes it difficult to transcode to MPEG which is likewise a highly compressed format, and this is made worse by the fact that it's a buggy codec to begin with.
Uppance: converting it will be a slow process, even slower than WMV and DivX because of its structural problems.
Fix: don't use XVid as a source file if you can help it.
Terry Stetler
Terry Stetler
Super resides here;
http://www.erightsoft.com/SUPER.html
Download link at the bottom of the page.
Yes, it may convert faster because it has less overhead than a full editor, but it also uses a rather low quality MPEG encoder compared to VideoStudio. Then again with XVid as a source....
Terry Stetler
