4hr Capture Halts @ 41mins/System Freeze
Lagarto_Roca
Post by Lagarto_Roca »
MF5+ trial
After several test runs @ shorter durations to adjust all settings, I set Auto Capture @ 4 hour duration. Came back, tuner audio running (as before) but, system won’t respond and activate Monitor from power saver mode. So, no status or error messages available for viewing.
After re-start, I imported the capture file but, only 41 minutes captured.
I edited with AdZapper and burned remaining 32 minutes with SPECTACULAR results, incredible playback on DVD up-convert to DLP HD.
Large edit screen, ease of use and clear, sharp image, auto capture, low CPU usage, this is the best software I’ve found.
Are there any apparent conflicts with my settings? Did the halt occur because the PROJECT TYPE was set at DVD 4.7G? The 41 minute cut-off was a bit early for 4.7G.
If so, should I up it to the HD level and after edits, set correct size before the burn?
Ulead DVD Movie Factory 5.30.0107.0
PROJECT SETTINGS:
MPEG files
24 bits, 720 x 480, 29.97 fps
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 256 kbps
CURRENT PROJECT TYPE:
DVD 4.7G
CAPTURE FORMAT:
DVD-HQ 4.3
VIDEO PROPERTIES:
Input Source TV NTSC_M
Set Auto Capture 4.0 hrs.
Audio Device Realtek AC97 Audio
Input Source Line In
AMD64 3000+, 2.0G PC3200/400
ABIT KV8-PRO nVidia 6800GT/oc
Leadtek Winfast TV2000 Deluxe, MyHD mdp-130
WD 74 GB RAPTOR, MAX 200 GB sata/150, SEA 400 GB uata/100
Emprex 16X dual burner & BTC DVD-Rom
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 10:50 pm, edited 1 time in total.
Lagarto_Roca
maddrummer3301,
Thanks for your response.
I figured as much on the length not being an issue in capture, only at the burn.
Several test runs for 10 to 15 minutes with same configuration (power and screen savers, virus….etc.) had no probs.
I had found one error but, the time stamp was much later than this occurrence so, I didn't mention it in original post:
9/2/2006 9:30 PM Application Hang Hanging application DVDMF.dat, version 5.0.0.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
Will try again with longer duration.
